https://8378simtek.wordpress.com/products/
Also got some inspiration in the mail today
And when this car is built I'm moving on
What are your thoughts on reinforcing/replacing the crossmember? I asked on one of the Facebook rally groups and was given the 3rd degree. The first handful of replies said "that's dumb, just buy a TSS," followed by "that's dumb, the factory cross member is the 'fuse' in the system. You'd rather have a bent cross member than bent frame rails right?" And finally "that's dumb, extra metal and reinforcement in the engine bay is a huge safety hazard that stuff is supposed to crush in an accident." So I handed it off to the co-driver so he could power wash it and we'd stick it back in.beatersubi wrote:We should talk. I could beef up a crossmember. Or make one similar to whats commercially available.
John is as interesting guy. Very opinionated. I've had some (long) interesting conversations with him, mostly about Ford, Merkur, and Cosworth stuff. But also about him hanging up his hat on building suspension and having someone take over. He was still fairly guarded about his sources and techniques, though.
Those magazines look awesome! Where did you find them?
You're not really switching to a Mini, are you?
Yes. And we haven't even got to start it up.beatersubi wrote:So, there is cooling getting into the oil somewhere?
Not off to a great start. I walked away from the car for a while just to quell my frustration. Got back to it this past Monday.beatersubi wrote:A compression and leak-down test would be a good start, especially if you suspect the head gaskets.
I think it has something to do with the Kill switch I wired in. I’m going to see if they have a diagram for it today.beatersubi wrote:Sorry to hear about your frustrations. Stick with it, it'll be worth all the trouble.
Did you verify cam timing is correct?
Check ECU grounds?
This per the 1993-1996 JDM GC8 F.S.M - Head resurface limitations.bmxpunk wrote:I also need to revisit the old heads again. Is there a way I can measure them to see if they were milled too much?
Thank you!
