machine shop
ride_child
machine shop
Post by ride_child »
I didn't know where else to put this haha
I'm in gathering parts really fast for my engine build, so I need to find a good machine shop to get my work done at. I'm located in enumclaw, wa, but I'm willing to drive a bit if it's worth it. Thanks in advance!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
mr.blub.blubs142
Re: machine shop
Post by mr.blub.blubs142 »
Not sure if you’d want to drive all the way down to chehalis, but Barry’s Quality Machine down here here is pretty damn good.
Mister Anderson
Re: machine shop
Post by Mister Anderson »
I used Bearing Service Co in Portland, Oregon when I had the machine work done for my stroker 2.2. For the 2.0 I’m going to be using Gibson performance in Spokane, Washington.
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
ride_child
Re: machine shop
i dont mind chehalis, ill look it up.
portland and spokane seem a little far, butill keep it in mind!!
thanks everyone
Kris
'91 Black SS - SOLD
Re: machine shop
Make sure the machine shop is very familiar with Subaru motors and whether they use a torque plate when machining, etc.
ride_child
Re: machine shop
awesome, thanks for the info josh!!
Kris
'91 Black SS - SOLD
carfreak85
Re: machine shop
Post by carfreak85 »
Torque plates in place of both heads and a line bore of the crank mains. Don't rebuild a turbo Subaru block without doing this.
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
Re: machine shop
I don't know whether the machine shop I used to rebuild my motor used the torque plate or not. I found out about that afterwards. Which is why I suggest using someone that really knows Subaru motors.
Re: machine shop
I've had a couple blocks done at Action Machine in shoreline. Very professional, and I believe they use a torque plate if you ask.
carfreak85
Re: machine shop
mike-tracy wrote:I've had a couple blocks done at Action Machine in shoreline. Very professional, and I believe they use a torque plate if you ask.
I and a friend have used Action Machine in the past as well, with good results. This is when they were still in Kirkland though, not sure what has changed since they moved.
1987 RX Type-RA
2002 WRX sedan
ride_child
Re: machine shop
ill look into them, thanks!!
Kris
'91 Black SS - SOLD
