machine shop
ride_child
machine shop
I didn't know where else to put this haha
I'm in gathering parts really fast for my engine build, so I need to find a good machine shop to get my work done at. I'm located in enumclaw, wa, but I'm willing to drive a bit if it's worth it. Thanks in advance!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
mr.blub.blubs142
Re: machine shop
Not sure if you’d want to drive all the way down to chehalis, but Barry’s Quality Machine down here here is pretty damn good.
Mister Anderson
Re: machine shop
I used Bearing Service Co in Portland, Oregon when I had the machine work done for my stroker 2.2. For the 2.0 I’m going to be using Gibson performance in Spokane, Washington.
ride_child
Re: machine shop
i dont mind chehalis, ill look it up.
portland and spokane seem a little far, butill keep it in mind!!
thanks everyone
thanks everyone
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Re: machine shop
Make sure the machine shop is very familiar with Subaru motors and whether they use a torque plate when machining, etc.
ride_child
Re: machine shop
awesome, thanks for the info josh!!
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
carfreak85
Re: machine shop
Torque plates in place of both heads and a line bore of the crank mains. Don't rebuild a turbo Subaru block without doing this.
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
1987 RX Type-RA
2002 WRX sedan
Re: machine shop
I don't know whether the machine shop I used to rebuild my motor used the torque plate or not. I found out about that afterwards. Which is why I suggest using someone that really knows Subaru motors.
Re: machine shop
I've had a couple blocks done at Action Machine in shoreline. Very professional, and I believe they use a torque plate if you ask.
carfreak85
Re: machine shop
I and a friend have used Action Machine in the past as well, with good results. This is when they were still in Kirkland though, not sure what has changed since they moved.mike-tracy wrote:I've had a couple blocks done at Action Machine in shoreline. Very professional, and I believe they use a torque plate if you ask.
1987 RX Type-RA
2002 WRX sedan
1987 RX Type-RA
2002 WRX sedan
ride_child
Re: machine shop
ill look into them, thanks!!
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
