Joe's 93 RHD Legacy Wagon Build
Sublimejoe
Re: Joe's 93 RHD Legacy Wagon Build
Post by Sublimejoe »
My downpipe came yesterday. I was going to install today but had to put a starter in my wife's car. Womp.
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
dankberries
Post by dankberries »
Sublimejoe wrote:To hook up my fan I can use the B wire as ground, and the YR for power.
That is correct.
One thing that's also good to look at in FSM is pin placement on the connector, for example , on the fan connector it shows Ground at pin 1 and power at pin 3.
Sometimes wire colors don't match up with the FSM making it not 100% reliable to entirely go off of wire colors.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Sublimejoe
That is correct.
Awesome thanks! One step closer
Parts Needed:
Manual Cluster
Are you hooking up the stock fan or aftermarket?
Are you planning to use just the one connector you took a picture of on the passenger side or both the one on the passenger side and driver's side? The wiring colors are not the same. Is the AC short connector connected? It should be located around the passenger side headlight in the wiring harness and should be connected.
If you're using aftermarket fans and assuming you want to be consistent you should use the Black wire as ground (pin 1) and the yellow wire with a red stripe on the driver's side connector for power and the white wire with the blue stripe on the passenger's side connector for power.
That is correct.
The wire colors are pretty good with matching up as long as you're using the correct FSM and looking at the right spot.
Sublimejoe
Legacy777 wrote:Are you hooking up the stock fan or aftermarket?
Yeah that’s actually the only connector for fans. It looks like there was one in the same spot on the left side of the bay but someone cut it off. I will look for the a/c short connector. I believe I saw it tucked in fender. I will not be running a/c, does that change my need for that connector to be plugged in?
Parts Needed:
Manual Cluster
If the AC short connector is not plugged in both fans do not operate together. You need the short connector connected if you want the "AC" fan to operate with the engine control vs. AC control.
Sublimejoe
Ah ok I get it now!
Parts Needed:
Manual Cluster
Sublimejoe
Was hoping this would not be the case, but the EJ20g intake manifold that I purchased never came, the guy Bs'd me for weeks so I am assuming he never sent it, and never will. Sucks because I got double burned, the K manifold that I sold ended up being a fortune for shipping and I ended up paying for that. Cost more to ship it than I even sold it for.
Get me out of this manifold hell.
Parts Needed:
Manual Cluster
Sublimejoe
Put my DP on
Parts Needed:
Manual Cluster
Sublimejoe
Alright people, mark my words, this is the last intake manifold I am buying for this motor. If this one doesnt show up Im turning the Legacy into a pedal car.
Parts Needed:
Manual Cluster
Hopefully you actually get this one :)
Sublimejoe
Right! Tracking says it will be here Friday, so at least I know he sent it. Or something in a box Hahahaha
Parts Needed:
Manual Cluster
ride_child
Post by ride_child »
if that doesnt work. ill send you mine. that way you get it for sure.
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
Sublimejoe
Thanks man, you’re the best :)
Parts Needed:
Manual Cluster
Sublimejoe
Bolted the manifold on today. The two inner bolts on each side were too short, gotta get some longer ones, thanks Mike!
Here are some photos. I am going to sit down later and print out the pages with vacuum hose diagram etc and figure out where everything goes.
Blue plug goes where?
What is missing here on the throttle body?
Parts Needed:
Manual Cluster
ride_child
i believe thats for your tps on the throttle
Kris
'91 Black SS - SOLD
Sublimejoe
ride_child wrote:i believe thats for your tps on the throttle
Radical! I know I have one somewhere.
Im searching for a diagram of where all of the hoses go and I cant find quite what im looking for. Does anyone here happen to know where I can find?
<3 <3 <3
Parts Needed:
Manual Cluster
dankberries
Blue connector is Canister purge control solenoid.
90 Nissan 240sx 2jz
Sublimejoe
dankberries wrote:Blue connector is Canister purge control solenoid.
Rad. I now realize Mike Tracy told me that twelve times and I just cant read.
Also, I need a MAP sensor. Anyone wanna help a brotha out?
Parts Needed:
Manual Cluster
ride_child
i think i have some diagrams of the hose routing if you wanna send me your email, ill send um to ya!
Kris
'91 Black SS - SOLD
Sublimejoe
ride_child wrote:i think i have some diagrams of the hose routing if you wanna send me your email, ill send um to ya!
Rad! Its Sublimejoe at gmail
Thank you kindly
Parts Needed:
Manual Cluster
Sublimejoe
Ok I am back, been busy with work but Im ready to do a few more things.
Next thing I want to get figure out and purchased is intake setup. What is the simplest possible setup I can do? Would it be just a 90 degree elbow to some sort of short ram type of thing? I do not have any of the stock airbox stuff.
Parts Needed:
Manual Cluster
Legacy777 used parts from an NA, such as the air box, to decrease the amount of 90* bends in the stock turbo intake tract.
Of course a short ram "hot air intake" would be easiest, I'm just not a fan of pulling in hot engine bay air, when you have an easy source of cold air through the fender. Of course that aftermarket intake could be extended to go through the fender.
Sublimejoe
So say this particular car has a hood that won’t close anyway and is therefore going to stay hanging on the garage wall. Short ram? :)
Parts Needed:
Manual Cluster
