Joe's 93 RHD Legacy Wagon Build
Sublimejoe
Re: Joe's 93 RHD Legacy Wagon Build
Rad! I’m in Virginia, just outside of DC. Where you headed?
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Manual Cluster
One thing to note is that if you use a 90 degree silicone on the inlet side of the turbo make sure it's beefy and/or rated for vacuum. Others have reported the silicone 90's collapsing under hard acceleration when the turbo is drawing in a lot of air.
ride_child
good note.
ive found the stuff from siliconeintakes.com is pretty beefy and i havent had an issue with their stuff yet
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
ride_child
dang thats a little too far north, ill be going from orlando to north carolina
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Sublimejoe
Ah man. That is a nice drive though. Are you stopping anywhere in particular along the way?
Parts Needed:
Manual Cluster
Manual Cluster
Sublimejoe
Ordered another silicone 90* and ten feet of 3.5mm vacuum hose. Thanks to everyone who explained to me ten times that I also need a section of pipe to go between things!
Parts Needed:
Manual Cluster
Manual Cluster
ride_child
visiting friends in orlando, then a buddy in atlanta, then my cousin in nc!
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Sublimejoe
Oh nice! HOTLanta!
Parts Needed:
Manual Cluster
Manual Cluster
ride_child
HOTlanta for sure haha!
sorry i havent got you pictures of my intake setup yet. did you get it all figured out?
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Sublimejoe
Hahahahaha, I honestly haven't been there since 2000, but I imagine its the same.
Its all good. I have all the information, now I just need to make it happen. I did get some 3.5mm vacuum hose today though, so thats a good start.
I should've gotten black.
Parts Needed:
Manual Cluster
Manual Cluster
Sublimejoe
Alright, went to the garage today for a couple minutes and I put the new silicone 90 on the turbo. The intake manifold smooshes the 90 a bit, I envision that will be a problem, yes?
Imgur isn't working, so this is where photos would be.
Parts Needed:
Manual Cluster
Manual Cluster
Sublimejoe
Here are the photos:
Parts Needed:
Manual Cluster
Manual Cluster
ride_child
see if you can trim more off of the turbo side of the elbow. to make it more extreme of an angle if that makes sense.
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Sublimejoe
Looking at the 90 I feel like I could cut over an inch off it and still have room for clamp
Parts Needed:
Manual Cluster
Manual Cluster
JimBos Legacy
I had the same problem with some plumbing hose that I used for my 90 degree elbow. I just bought a 90 degree silicon hose that’s made for turbos online line for like $5. You have to shave it really close to make it fit perfect.
And sorry for the Snapchat filters these are the only pictures I have
JimBo
1992 JDM Subaru Legacy GT wagon
ride_child
yep i owuld just trim a little at a time and see how it fits every time. i find when i do silicone cutting i always cut too big first and fuck it up haha
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Sublimejoe
Ok, I trimmed one of the legs about as far as I could It definitely helped a bit, but the intake manifold still crushes it maybe 15%. If I rotate the 90 clockwise a little it helps, but it of course turns the 90 the wrong direction. I used a piece of PVC to test fit.
Thoughts on all of this?
Parts Needed:
Manual Cluster
Manual Cluster
ride_child
looks pretty tall and looking from the front it looks to be "leaning back" a bit. how is the hood clearance? the hard plastic will make it easy to weld in your ports.
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Sublimejoe
The hood won’t close because I used a turbo radiator, so I’m not too worried about the hood clearance quite yet. I should probably just take the turbo to a friend and have them weld a 90 on. Shouldn’t I?*
Edit * - Are all cast elbows the same for the most part? This one is a super tight radius 2.5"
https://www.amazon.com/Vibrant-Performa ... 1FX3ECJ1F7
Parts Needed:
Manual Cluster
Manual Cluster
ride_child
i think you should be good with that cast elbow, if you are going to find someone to weld cast aluminum you might as well have them put on a little extension just to make sure you have enough material to clamp to.
if i was in your position, id go this route. i dont know if that should make you feel better hahaha
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
ride_child
if you wanted to stick with the silicone 90, id say you could cut a bit off the vertical portion to suck the hard 90 down to more tolerable levels.
im leaving that statement open for all to tear apart hahaha
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Sublimejoe
Hahahahahride_child wrote:if you wanted to stick with the silicone 90, id say you could cut a bit off the vertical portion to suck the hard 90 down to more tolerable levels.
Also, received these today. Map sensor etc. These should be the last of the turbo specific sensors I need.
Thanks, Isaac!
Parts Needed:
Manual Cluster
Manual Cluster
Sublimejoe
Well, my lovely internet friends, I made a quick decision for once and pulled my ej20 and dropped in a running ej22. My friend Skylar came down from dirty Jersey and we pulled the 20 out and dropped in the 22 in a couple of hours. Got everything bolted down and plugged in. The car didn’t crank for some reason, but the accessory power worked and all of the exterior lights and dash lights worked, for the first time in many years!
I’m not entirely sure why it’s not cranking but it was pretty late by that time so I put everything away for the night. I know that all of the grounds are not connected. Another issue I have is the exhaust manifold doesn’t fit because I have a turbo crossmember, any suggestions to work around that?
Those AUSDM tail are fire.
Parts Needed:
Manual Cluster
Manual Cluster
Do you mind refreshing us on what all that's been done....sorry I know should review the previous posts, but have limited time.
What ECU are you running? Was the car original auto or 5spd and what is in it now? Have you tried a manual start button to see if you can bypass the ignition key and get the starter cranking?
I know it may be a silly question, but is the battery fully charged and good?
Sublimejoe
The car was originally automatic and is now five speed. I am running the stock ecu still. I pulled the week old battery out of my truck, so it is pretty good to go.
I have not bypassed the ignition to try starter yet.
Parts Needed:
Manual Cluster
Manual Cluster
