92 taillamps
ericS2the6
92 taillamps
Post by ericS2the6 »
Just been thinking :) , the tailamps on the 92's have a clear lens with an amber bulb, yet this was changed for 93/94. Anybody know why?
I believe the overall design is still the same isn't it? So one could go about collecting some from a salvage yard and connect them to a later year legacy. I wouldn't think it would be to hard to find a set either, seeing that all trim levels iirc were equipped with them in 92.
Has anyone done this or given it any thought. I think it just looks cleaner with the orange lacking.
or is it just my imagination :oops: i swear ive seen some us spec legacys with them tho!
Not sure you have the right years. 90-91 have a clear bulb but an orange plastic piece in there. Without disassembling the light you really can't get it out.
The 92-94 models I believe have the orange light instead.
ericS2the6
ok perhaps i wasnt being clear.
i own a 93 legacy.
I would like to put on the 92 taillamps. Im questioning whether the only difference between the years is the fact that the 92s have a clear lens.
so they should hypothetically fit on a 93/94 legacy.
i just wanted to check with you guys becuase im baffled on why they would make this change.
kelley
Vendor
Vendor
Post by kelley »
Oh yeah , I never noticed that. the 92 also doesn't have those lines where the amber bulb is. I like that better. I don't see why they would not interchange. but I will find out.
Sorry,
I misunderstood you. yeah, the 92 & 93-94 models should be interchangeable.
Just curious though.....did you take those two pictures of the rear tail lenses?
I just checked the parts sheet.....they definitely do list a different part #'s for the 92......bizzare.....
Js92Tru
Post by Js92Tru »
Just a clairification with the 92 tail lights they still use a clear bulb but have an orange insert behind the clear portion of the lens snaps in kinda like a lego peice so it should be easy removal if the housings are not on the car.
Jay
For sale -'92 White Legacy Turbo Sedan (US Spec) STi shifter, STi strut Mounts, KYB AGX struts, Eibach Springs, 16" 97 GT rims, Potenza RE950 tires and others.
His - 99.5 Audi A4 1.8 TQMS (Brilliant Yellow) w/ some Mods
Js92Tru wrote:Just a clairification with the 92 tail lights they still use a clear bulb but have an orange insert behind the clear portion of the lens snaps in kinda like a lego peice so it should be easy removal if the housings are not on the car.
Jay
Yeah....the 90-91's are like that......only problem is getting it out.....
HomeSlice
Post by HomeSlice »
I CHANGED MY93'S TAILS WITH 92 TAILS NO PROB-
-JIM-
93BC"edm" 93GC 90BC R.I.P.
ericS2the6
homeslice wrote:I CHANGED MY93'S TAILS WITH 92 TAILS NO PROB-
-JIM-
good going homeslice :D
thanks!
HomeSlice
Post by HomeSlice »
no prob man----its looks a helva lot nicer with out that nasty amber-- now you just got to make some custom side markers to match---i did check out mine on my website.
Cheers
-Jim-
kelley
Vendor
Vendor
Post by kelley »
hey homeslice I see that youinstalled a japanese electronic climate control. Do you have a picture of it. I would like to see what it looks like. thanks, kelley.
HomeSlice
Post by HomeSlice »
totech
Post by totech »
Homeslice,
So you installed the JDM auto climate control.
Was it a direct plug in? Easy to do?
08 GE - SWP
96 BG - SGP
96 CX - EBP
HomeSlice
Post by HomeSlice »
only if you already have the digital climate in from the factory. thing that sucks is the us only got it on the 90-91 lsi's. so i got to change all the wiring and hookup the vacum modules to work corect. im trying to locate the wiring and heater box from a lsi so i could hook mine up. the unit gets power but the temp control does not work. once i figure it out i will post the parts you need. i am waiting to do the install when i change out my L interior for the turbo interior. i will already have the dash down to nothing and i can access the climate control more easy.
-Jim-
totech
Post by totech »
That was my thought - the temp that runs off a cable would not work, does the rest plug in?
Looks really good though!
08 GE - SWP
96 BG - SGP
96 CX - EBP
totech
Post by totech »
08 GE - SWP
96 BG - SGP
96 CX - EBP
HomeSlice
Post by HomeSlice »
yup it plugs in
