Just been thinking , the tailamps on the 92's have a clear lens with an amber bulb, yet this was changed for 93/94. Anybody know why?
I believe the overall design is still the same isn't it? So one could go about collecting some from a salvage yard and connect them to a later year legacy. I wouldn't think it would be to hard to find a set either, seeing that all trim levels iirc were equipped with them in 92.
Has anyone done this or given it any thought. I think it just looks cleaner with the orange lacking.
or is it just my imagination i swear ive seen some us spec legacys with them tho!
Not sure you have the right years. 90-91 have a clear bulb but an orange plastic piece in there. Without disassembling the light you really can't get it out.
The 92-94 models I believe have the orange light instead.
Oh yeah , I never noticed that. the 92 also doesn't have those lines where the amber bulb is. I like that better. I don't see why they would not interchange. but I will find out.
Just a clairification with the 92 tail lights they still use a clear bulb but have an orange insert behind the clear portion of the lens snaps in kinda like a lego peice so it should be easy removal if the housings are not on the car.
Jay
For sale -'92 White Legacy Turbo Sedan (US Spec) STi shifter, STi strut Mounts, KYB AGX struts, Eibach Springs, 16" 97 GT rims, Potenza RE950 tires and others.
His - 99.5 Audi A4 1.8 TQMS (Brilliant Yellow) w/ some Mods
Js92Tru wrote:Just a clairification with the 92 tail lights they still use a clear bulb but have an orange insert behind the clear portion of the lens snaps in kinda like a lego peice so it should be easy removal if the housings are not on the car.
Jay
Yeah....the 90-91's are like that......only problem is getting it out.....
no prob man----its looks a helva lot nicer with out that nasty amber-- now you just got to make some custom side markers to match---i did check out mine on my website.
Cheers
-Jim-
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White 93BC"edm"93GC90BC R.I.P.
hey homeslice I see that youinstalled a japanese electronic climate control. Do you have a picture of it. I would like to see what it looks like. thanks, kelley.
only if you already have the digital climate in from the factory. thing that sucks is the us only got it on the 90-91 lsi's. so i got to change all the wiring and hookup the vacum modules to work corect. im trying to locate the wiring and heater box from a lsi so i could hook mine up. the unit gets power but the temp control does not work. once i figure it out i will post the parts you need. i am waiting to do the install when i change out my L interior for the turbo interior. i will already have the dash down to nothing and i can access the climate control more easy.
-Jim-
