Where do I start...
Where do I start...
I bought a 91 Legacy turbo sedan from a farmer who used it as his "town runner". The car seems to be in great shape for it's age and milage (147,000+); the engine runs strong, and the transmission doesn't skip a beat. A couple things that I have noticed, most of the under hood hoses are starting to dry rot (air, fuel, oil, coolant); and it seems that the maintenance done on this car was just enough so he could get into town (which tells me this is a good car since not a lot was done to it ). My questions: 1. Is there any hose kits out there that will replace the under hood hoses? 2. Should I buy an overhaul kit to replace seals that may be past their prime?
I guess I'm looking for any suggestions that will help my Subaru run better and longer. Thanks for any help.
jesus that's cheap, definately put some moolah in that baby. As far as hoses you can try a samco kit for like the impreza or something, but some of them might be in different places, I dunno if there are any hose kits for our cars cause I haven't looked. You can also go up to home depot or something and just buy the sizes you need.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
You can replace most of the hoses with generic by-the-foot stuff. (Or is it by-the-centimeter where you are? You don't say your location.)
This'll tell you where most of the hoses go and their sizes:
http://www.graphics.cornell.edu/~v/vacuum/
The fuel hoses are 7.5mm, I believe. I have 5/16" fuel hose on my car. If you replace it be sure to use fuel injection hose and not just regular fuel hose; you need something designed to handle high pressure.
The blowoff valve and IAC valve hoses left out of the vacuum diagram are all 19mm. I don't think generic pieces will work so well here though.
LegacyT-The body is in pretty decent shape. A couple of dings here and there and a little rust around the wheel wells. I thought it was black; however, after I cleaned and buffed the paint, I started to see some deep red metallic flakes. So I'll call the color black cherry.
THAWA and vrg3- Thanks for the info on the hoses. I've been looking for a couple months for a kit (since all the hoses are pre-molded it seems), thats what brought me to this site. I knew nothing about Subarus until I bought this car; hopfully, I'll be able to learn quickly. Are late modle Impreza's and Legacy's compatible? Thanks again.
In what ways compatible? The Impreza was built on a shortened Legacy chassis, so nearly everything is compatible, though there are changes to some things over the years... If you're referring to the hoses, I couldn't tell you. I would doubt that all of them would be compatible, though some would very likely be in common. The turbos and the WRX have to meet different emissions standards and are different engines (SOHC vs. DOHC, different ignition systems, block, etc.).
Many of the molded hoses can be replaced with plain unmolded hose. You'll just have to remember where everything goes because the hose shapes won't be able to remind you.
My car doesn't have a single molded vacuum hose smaller than 10mm on it anymore, for example.
As for late-model Subarus, some hoses will be similar and some won't.
evolutionmovement- As far as compatibility, I was just seeing a few references to the Impreza while I was searching the site, I wanted to ask so I would know if I had a wider parts base to look at.
vrg3- I thought I would have to go with the unmolded hose, just wanted to see if there was anything out there. I was looking for a kit 'cause some of those angles in the hoses are pretty sharp, didn't want to bind or restrict any flow.
