Where to tap sensor/sender for oil pressure gauge?
I just ordered an oil pressure gauge but am wondering where the best place would be to tap the sensor sender into?
Yeah, you could tee off where the stock sender goes if there's enough room. I believe the threading is 1/8" BSPT.
Something like this might be useful:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2465562021
The sender actually threads into a bushing that threads into the block. There's another spot near the back of the block that has the same threads. So if you get another one of those bushings (it's 1/8" BSPT to M18x1.5 if I remember correctly) you could put it in the other spot to avoid teeing.
Try to keep your threading straight -- 1/8" BSPT and 1/8" NPT kind of thread together but really shouldn't be mixed.
I think you can thread one into the other but you have to seal it with teflon tape or something and you can't thread them the other way around. I can never remember - I used to just order the correct parts.
dagsy - I don't remember exactly where it is... It's on the top of the block towards the rear though. I think it's got an 8mm allen head.
Steve - You can thread 1/8" BSPT male fittings into 1/8" NPT female ones without damage or leaks if you use enough sealant. Ditto for 1/2" and 3/4" threads. Other than that, BSPT and NPT are incompatible. In any case, you always need to use dope or teflon tape with tapered threads.
vrg3 - that's it! That's the way I thought it was because it was the opposite of what I usually had lying around to work with.
Some interesting information provided guys, as always! I'll have to go to the dealer this morning and try and find that part. I found the part numbers on nasioc.
Well, I got the adapter piece from Stohlman today. About $8-9 for the part. They didn't have the gasket in stock but it looks like a regular crush washer will work.
Hopefully, our blocks have the same provision as the wrxs.
I looked on my engine today and saw the plug. It's on the block underneath the IAC valve and a little towards the passenger side. It's basically in a position symmetrical to that of the stock sender.
I'd like to install an oil pressure gauge too; I'm thinking of running my 1/8" NPT tap through a stock sender adapter to retap the BSPT thread into an NPT thread. If I remember right, BSPT taps remove a little less material than NPT taps, so this should work.
That's a good idea for the retap, vrg3. I'll keep you guys updated when I get started on this project. It's a little too cold down here.
It's actually a cheap ebay ricer gauge, placeholder until I can get a hold of my friend's Greddys *crossing fingers*
I just want something better than the oil pressure warning light and stock water temp gauge. With everything acting up lately with my waterpump and all, I figure it'd be better to have some preventive measure for future "incidents."
I was awfully happy I had that a/f gauge installed on my car when I was having those run-lean problems.
boostjunkie...
can you tell us more about your a/f gauge? Is it attached to a stock o2 sensor? Which one? what kind of accuracy/info do you get from it?
thanks...
Might be a stupid sounding question, but I here some people say that it only works at idle, others say only at full throttle, etc,
thanks...
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
It works the same as the autometer one I installed on my/your car (you still have that gauge in there right)?
Yes, they're useless for tuning, but when the gauge reads ALL THE WAY RED, I know something's wrong.
