3" sounds sweet
3" sounds sweet
i just got 3" put on my car and i love it, it sounds very mean. I have some talon friends and its sounds way better then there cars. I think that anyone here is thinking about changing there car going to 3" is the way too go.
As i've said before, boxers just sound awesome, turbo or not, with a big exhaust. I still maintain that the meanest sounding Subaru i've ever heard was a friend's 2.5RS with equal length headers and a full 2.75" exhaust no cat and Magnaflow straight-through.
Legacy Central
how does one get that really low bass type sound at like 1300 rpm?? Will a magnaflow muffler give it that sound?
Mark,
Mark,
ciper: on the contrary, that 2.5 was faster than my car, and when he removed the headers he says he easily lost 20hp instantly.
Legacy Central
Like a Honda?ciper wrote:20 hp at high RPM, Im talking about overall. Its no fun to drive a car with less low end power.
I recently installed the Cobb equal length headers on my RS and it made a noticeable diff. in power throughout the range with no loss in the beloved low-end (butt-dyno method) but the cool boxer sound was sacrificed a little since the equal length seems to alter the note quite a bit. My Legacy actually sounds better now since I need to replace the worn-out cats soon...
-B
-B
2000 2.5RS Sedan
1996 Impreza L Wagon
1998 Outback [gone]
1998 Legacy GT wagon [gone] :(
1993 Legacy Touring Wagon [gone] :(
1988 Mazda 323 GTX [gone] :(
1998 Outback [gone]
- quasi-mod-o
You are wrong. Sorry.SubySleeper wrote:3" is just fine for all subaru cars that are of 2 liters and up, especialy for the turbocharged models. on the n/a models, as long as you don't have stupid and lame backfireing, more power to ya
kyle
Exhaust velocity is key. To large, velocity decreases and you LOSE power. To small, velocity is physically maxxed and you increase backpressure (bad).
Think of it like a straw. Blow through the straw. Imagine blowing through a larger straw. It would take a lot more effort to get the same flow, eh? Now put a kink in the straw. You have to blow pretty damn hard to get the velocity to be the same.
The first instance is low velocity. You need a lot of exhaust to produce the most efficient velocity. Turbo cars make this velocity, N/A cars don't.
The second situation is backpressure. Backpressure it the enemy of exhaust systems.
The key?
As little backpressure as possible with as high velocity as possible. 3" pipes seem to give this balance on a turbo car. On an N/A car, you are going to have low backpressure, but low velocity as well. You could run a 2.25" pipe on an N/A and have little to no increase in backpressure and an increase in velocity.
There are formula's out there to determine the exact pipe diameter based on a series of factors (as well as ratings). General consensus is, 2.75" to 3" on a Turbo car.
