HI,
does anybody have a good idea for this topic? I'm thinking about doin this because i hit the passenger-side door to side pole when i tried to park my subi and made big dent. so, i thought this is the cheapest way I can replace it. so if you have any idea, please reply.
thanx for looking
Has anybody ever done swapping the door by yourself?
BF legacy 240000 mi
- Spelling Nazi
The difficulty is in lining it back up. Get one or two jacks that you can level to adjust the angle (both vertical and horizontal), height, and depth. If you leave the old hinges on it should be relatively easy (although you'll still need the jack to keep the door up unless you're a house like Hardy and can hold it with one hand). There'll probably still be a little tweeking required, but it should be close. I wouldn't want to pay a body shop to replace it - have them repair it, it'll likely be a lot cheaper.
finger...evolutionmovement wrote:(although you'll still need the jack to keep the door up unless you're a house like Hardy and can hold it with one hand)
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
i done it mad times by myself. i just rest the door on my boots. put a couple bolts in then go from there.
93BC"edm" 93GC 90BC R.I.P.
