NE1 make the switch to R-134?
It's getting warmer out nowadays and I've completely forgot that the A/C needs to be recharged. However, I'm thinking that this car uses R-12 refrigerant, which you can't find anymore. Has anyone done the switch to R-134? I hear there are kits available for this. Does anyone have experience with this procedure?
thankfully my R12 is holding up nicely. it's been pretty warm here for a few of the days, and it still blows ice cold
. Unfortunately I hear the R-134 kills the bag in the drier canister. I dunno what can be done about this. I guess it'll work fine for a while and it'll flake out after some time. something to do with the particles of R-134 being smaller than R-12 particles. I dunno the details. good question for a tech.
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
I know a little about Subarus.
-IggDawg
You can get retrofit kits from Subaru; I've had many people recommend getting OEM retrofit kits rather than using the "universal" ones sold at the local auto parts store (since they don't replace the receiver/dryer which is bad for the reasons IggDawg gives). If you have the tools and trust yourself with it, it can't be too bad to retrofit yourself; you'll just need to get any existing refrigerant discharged by a certified shop.
The kit for my car was part number G3110AS120: "92-93 Leg Cal A/C Retro Kit." I think I paid around $70 for it, and it came with:
73019AA100 PAG Oil
73035AA100 Pressure relief valve
73039AA010x4 O-ring
73058AA100 Adapter valve, low pressure
73058AA110 Adapter valve, high pressure
73411FA100 Receiver/dryer
SOA635054 R-134a retrofit label
I haven't tried using it yet; my A/C compressor died in October and rather than fix it then I just pulled all the A/C relays. Now I'm not sure if I'll fix and retrofit it or just pull the whole air conditioning system.
73019AA100 PAG Oil
73039AA010x4 O-ring
vrg3, do you remember where you got the kit for $70? I looked up the part number at subaruparts.com and they've got it listed for $187.57!!
I know a guy in florida that retrofitted his r12 system on his 93 wagon. He did pretty much everything vrg3 mentioned.....I've got the specifics in an email.
Other thing he mentioned is to fill the system only to 80% of the recommend pressure that the r12 system gives. The reason being is because the r134a stuff operates at higher pressures.
I've been contemplating switching. I had my system recharged last year with r12 for 50 bucks. It doesn't seem as cold now.......plus I would like to remove the condenser and clean it out......when I first turn on the vents in the morning after running the A/C.....it just stinks....so I'm pretty sure I got lots of fun stuff growin in there.
I would also like to know where this kit came from. I don't have a belt or tensioner pulley right now, but with the coming warm weather, I also want to look into getting the a/c working well.
Argh! So much stuff to do, so little money to do it with!
Yeah.....should be able to.....it's expensive though. 1lb of r12 cost me about $50 last year
ac
when i bought my car the AC did not work... so that summer, i got an estimate...$1300!!!!
But, for some reason, my mom decided to pay for it even though i told her it was too much and not to worry about it
!!! the compressor was $491!!! and a new evaporator for $236, new drier, expansion valve..... and they threw in the retrofit kit for $31.80......so labor was $335.50 and parts were $889.38 geez!! add tax and disposal fees and the total comes to $1308.97.....that crap should last forever now!! and if it doesn't..i will be very mad.... but hey....i didnt pay for it!
My system doesn't work as well with the R-134a though...especially with these florida summers... i have to keep it on max AC and number 3 or 4 all the time...the only time it gets really cold (around 32 degrees) is on the highway when there is enough air flowing over the condensor. but its better than nothing.
and Legacy777, do you mean the evaporator and not the condenser? the vent air doesn't flow over the condenser....if you take the glove compartment out, you should be able to get to the "Fan control amp." as the Haynes manual calls it. im not sure what this does, but if u take it out, you can see the evaporator.....maybe you can spray some type of antibacterial spray in there or that stuff that u can buy at auto stores meant for taking the smell out of the AC system.
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
A complete R-12 recharge will cost you around $100; it's hardly worth it even if you do have to pay $200 for a retrofit, since in the future it'll only get more and more expensive, while R-134a recharges are like $10.
If you do a retrofit, make sure it's done right. There are a lot of people who think R-134a is terrible because they had a shop retrofit their R-12 system to R-134a and they didn't do a good job. It's true that R-134a isn't quite as efficient a refrigerant as R-12, but the difference should be barely perceptible if at all.
I got this kit from an eBay auction; I remember having to look for a long time before finding one, though.
Supposedly you can recharge an R-12 system with propane, but I'm not planning on trying that anytime soon.
Josh, if you could post those specifics I'm sure we'd all appreciate it, provided the guy wouldn't mind.
Yeah....r12a is actually propane........which is how it's marketed.....no thanks.....I'll pass on the flame thrower A/C system.
I'll search back through my emails and find the info.
Good theft deterrent91White-T wrote:hmmm... now THAT would be something to haveLegacy777 wrote: flame thrower A/C system.
Well....I looked through my email....apparently some of the more technical discussions I had were on the phone with him.
Here's a brief excerpt
Hey Josh,
My compressor does the same, I think it might be the clutch bearing not sure though. I converted mine to 134A last year. I think it was less than a 100 dollars, $45 for new filter drier, $20 for 134a, $16 for flush solution and $12 for esther oil.
Took the whole thing apart flushed everything then put in new oil in compressor and drier then pulled a vacuum and charged with 134A and it gets really cold.
BTW taking the evaporator case out didn't come easy until I took all the hoses off. Hard to remember but I don't think it would come out until I took it apart. The evaporator has a styrofoam case around it.
I didn't replace the fittings to convert to 134A. I bought a converter that just screws onto the valve that pierces the freon can. I did this so I didn't have to buy a new set of gauges. I think it cost $12 at local refrigeration whse.
I sprayed some silicone spray on the clutch while running seemed to make it a little quieter.
Where I used to work the semi mechanics in the truck shop would dump 134a right on top of the R-12 if they thought the compressor was on its way out. But I wouldn't try it unless you knew the compressor was going bad. The compressors we have or a dealer only item and very expensive. You can only use the compressor from a 90 or 91 only. The junkyard ones go for about 100.00. The new from the dealer I think was around 500.
Call me if you have any questions.
Sincerely,
Hal Harrison
I'll try and give him an email or call and get the specifics on things.
Hey Josh,
Sincerely,
Hal Harrison
My '97 Impreza's air conditioning was impossibly cold. I had to periodically switch the air conditioning between the low and off positions a lot of the time, even when it was hot.
I think it's true that R-12 is a better refrigerant than R-134a, but I think there are so many other variables that come into play that it's far from being a determining factor.
I found this while researching info for the A/C system swap. I'm still gathering info.....so we'll see.
http://www.endwrench.com/pdf/heat/ACRet ... nfoS98.pdf
