Electronic Climate Control Swap..
magnux
Post by magnux »
So, I've completely enthralled with the Electronic Climate Control system I've seen in the JDM Legacies. From what a friend tells me, the USDM Legacy LSi came equipped with this as well, right?
In any event, what all is required for the swap. Is it a simple matter of swapping the Climate Control assembly, or is there more involved? Since my controls are currently lever based, how would they adapt to the electronic control.. is there an actuator of some sorts?
I really want to do this, I think that's just too damn cool. :)
MY93 EJ22T @ +1BAR
I suggest doin a search. There's a couple threads about it.
however I will warn you, this is not an easy task. There's various sensors and other stuff that need to be swapped as well in order for the automatic climate control to function properly.
IMO, it's not worth the time or money to swap unless you find a complete lsi you could take EVERYTHING out.....that's however not saying whether the wiring will be in place or not.
THAWA
Post by THAWA »
the usdm climate control is way uglier and I don't think as good as the jdm control. Usdm= amber, jdm = blue or something.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
BAC5.2
Post by BAC5.2 »
Hardy - Pics?
Flip_x
Post by Flip_x »
huh the usdm lights is amber? u mean the light on the switch?? thawa??
1990 Legacy Sedan LS AWD 5-MT 162k miles Slate Metallic (Sold to Brother)
1992 Legacy SS AWD 5-MT 180k miles Mica Black
