So, I've completely enthralled with the Electronic Climate Control system I've seen in the JDM Legacies. From what a friend tells me, the USDM Legacy LSi came equipped with this as well, right?
In any event, what all is required for the swap. Is it a simple matter of swapping the Climate Control assembly, or is there more involved? Since my controls are currently lever based, how would they adapt to the electronic control.. is there an actuator of some sorts?
I really want to do this, I think that's just too damn cool.
Electronic Climate Control Swap..
MY93 EJ22T @ +1BAR
I suggest doin a search. There's a couple threads about it.
however I will warn you, this is not an easy task. There's various sensors and other stuff that need to be swapped as well in order for the automatic climate control to function properly.
IMO, it's not worth the time or money to swap unless you find a complete lsi you could take EVERYTHING out.....that's however not saying whether the wiring will be in place or not.
the usdm climate control is way uglier and I don't think as good as the jdm control. Usdm= amber, jdm = blue or something.
