Here's my idea...
Here's my idea...
So, here's the deal. My father doesn't want me to get an exhaust due to the fact that it's "noisy" and he hates mods. So, I thought to myself, what's a good way to do the exact opposite of what he want's with out him knowing. Then it dawned on me. A dump tube. Not just a tube that comes from the turbo and bends down. Oh no. An electronic one. One where I can retain my stock exaust, but splice a electronic dump tube in, and open it when I need it. Now i need your opinions. Good or bad and why?
Dump tube link-(You can download a video of a tube in use with a WRX)http://www.quicktimeperformance.com/QTEC/index.html
98 LGT
I hope if you do that you have it plumbed out the side or something so you're not just blowing out hot exaust directly under your car.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
You mean an electronic cutout.
Good idea and bad idea.
If you've got a stock downpipe, don't bother. It's not worth it.
If it's a good downpipe with stock DP back, then go for it.
Be careful though, if it's a good downpipe (that is also cattless), you'll shoot flames. I know, I started the car with JUST the DP on, and when I revved it, anything above 4k and it'd spit a flame out.
I need to get it to do that out the back now too!
lol, which part? The floor scorching part, or the worthless w/o downpipe part?
stealth mod?
Sounds like a cut out, to me. JC Whitney sold cable operated "Y" valves that you could put in a standard exhaust pipe, and operate the valve by pulling on the cable handle (neatly hidden along the side of you seat??). I installed one on a friends 283 Impala. Lots of noise. No power.
On the other hand, there are mufflers with effective tip inserts, that quiet the exhaust by 5-6 db (quite a bit, actually). These mufflers are used in places where different tracks require certain noise limits. Easy to do. Works well.
Not as slick as throwing a switch, though.
Jeff
Heh, these are quite common in the F-Body (Camaro/Firebird) world. I used to have one on a couple of my Camaros, however, I was never a fan of the QTP model. The original, and IMHO, still the best is: http://www.mccordcg.com/mpp/mpp.htm
In any event, get a WRX exhaust and a custom (catless) downpipe. Your dad will never know you changed the exhaust.
MY93 EJ22T @ +1BAR
Tell your dad that it's your car, and you want to do this.
Explain the gas mileage benefits, and that it's not THAT loud.
My car, while being loud under WOT, is fairly sedate at idle and partial throttle.
I still want a cutout or something though, just so I can shoot flames out the side of my car.
Or maybe he should respect his fathers wishes seeing as how he's still being supported by him, and just live with a quiet exhaust. You wont die from it.
Shhh, Hardy. He won't die but he'll be sick at heart and worthless as a human being without it. Mod it!
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
so fuck it, just run wihtout headers, that mod enough for ya
