how thick
how thick
how thick are the saab 900 cores? and would a fmic thats 30" X 6" X 2" be good to cool a 15psi pluss charge down enough. ive found one for a pretty good price and am wondering if you guys think it would be worth it
-jason
Without going out to my garage or my car to check, I seem to recall them being around 3" thick.
An IC that large, you should have no problem with 15psi.
Where are you getting the IC and how much?
off ebay their all less than 200 some of them are like 27x9x2.75 cores. http://www.johnnyracecar.com/
the dude makes them himself and has a 100% feedback on over 600 sales
-jason
forget I said anything.......
I'm sure it works but i don't think there is any need for it to be that long, its better than a top mount anyway...
![Embarassed :oops:](./images/smilies/gear_oh2.gif)
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
Hmm, when you said he made them himself, I was skeptical but those look legit.
hmmmmmmmmm...................
No, bad phil! No more money! NO! NOO NO NO NO NO! Shit, i'll probably end up doing it sometime in the near future.
"Mom, can you get me an intercooler for my birthday?"
Only downside I can see is the small inlet and outlet pipe diameters. A 3" OD inlet and outlet would make me feel a lot better.
2.5" OD isn't too bad really. The Saab 900 units are only 2 1/4" OD so at least it's better then that. That unit should flow pretty well too since it's nice and straight through.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
3" would allow the use for press-bent tubing instead of the expensive mandrel sections that need to be welded in place. With 3" OD pipe, there's no need to worry about the pipe being mandrel pressed down to 2.75 or 2.5" ID. With a 2.5" pipe, there's a chance that it will be pressed to narrow.
Strictly from a cost standpoint, I'd like to see 3" OD end tanks.
or you could find a exaust shop with a mandrel bender.
oh and phill i think you ment "pipe being pressed down to 2.75." mandrel doesnt decreace the diam size.
and back to my original question. how thick are the saab 900 cores
-jason
like 2.5 inches...
Those ic's arn't too great, you can get much better tube+fin ic's for similar pricing. or, you can go to a bar and plate setup and get some real cooling...
dirt-covered 91 SS prorally
pat richard roll cage, DMS 50mm, stickers...
SOLD :(
99 impreza RS
ver. 7 sti swap, ver. 6 RA suspension, JDM bodywork, rotated GT28rs
SOLD :(
99 impreza RS
if there are any i havent seen them. cheapest bar and plate ive see were 350 bucksaspect wrote:Those ic's arn't too great, you can get much better tube+fin ic's for similar pricing. or, you can go to a bar and plate setup and get some real cooling...
-jason
