spooling
spooling
well i think it happend my turbo sounds like its on the fritzzs, tell me what you think.
when i make any boost, even reving the motor at idle the exhuste side of the turbo makes this crazy tinkle noise like its hitting the wall around the fan, is it on its way or am i fine.
it still works and gives me crazy boost but there is this crazy noise. should i get it out and replace the bearings cuz there toast, or leave it in and wiat till it PoPs.
how this noise came around, a bolt came out off my exhuste manifold and it was loose so i was not getting full exhuste power i put the bolt in and drove it around and the noise started. what your guys think it could be?
i looked every where vrg3, what i can tell it sounds like its comeing from the exhuste side off the turbo.
when driveing it i let off the gas at a high rpms it makes this crazy gurrggle sound.
factory stuff. dame i hope something didnt get loged in there i am goign to ripp it apart right now thaks vrg3 i will let you no what happens.
what would you think of some one rebuilding it and putting a bigger fan in the front with a boerd out housing he siad same spooling and more boost.
Do you know what material the factory gaskets are? I don't know.
If done right, that kind of rebuild and modification would be a lot like the T-bird compressor mod that you've already done, wouldn't it?
						come to think of it vrg3 it is like the t-bird set up. they want 1100. just to do that for me, what a waist.
about the noise still no clue on what is makeing it, it might be something loose around the turbo.
well guys i had to change the turbo. i opened it up and the inlet fan was toast, so i put in a new one. it still pulled hard.
				legacy92ej22t
I pulled my VF11, with 145k miles on it, out when I swapped in my 16G and it had zero shaft play.
 It's still in very good condition and was pushing 16 psi all day long.
							-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
i told my dad about that balancing the turbo, he siad its all
"bowl-a-shit". my dad looks for shaft play, busting fans, and craked houseings. if it dont have those symptoms its ok to use.
Yeah reciprocating parts rotating at 100,000 rpm will have no untoward vibrations.
				rsstiboy
he must be a very successful turbo mechanicNICO I WRX U wrote:i told my dad about that balancing the turbo, he siad its all
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
						best macanico in north america he gets all the exotics  ship from all around just to get them fixed, but he is getting old so you no what happens then, a hole lot of forgetting stuff.
