This is what you are looking at... Yellow/Cyan = EJ22T Sport Sedan, Green/Blue = AWD EJ22 NA.
Power Mod list for NA:
modified stock air box w/ paper filter (snorkel removed and added intake tube)
MSD Dis 2 ignition w/ diamond coil pack
magnacor 8.5mm wires (running stock ngk plugs)
HO alternator
1992 legacy balance & blue printed injectors
N1 aluminum pulley set
Exedy LW flywheel
MRT axle back muffler
Semi-power mods: (unleashers per se)
sti motor mounts
st trans mount
TB coolant bypass mod
extra earthing grounds from battery to chassis and starter
extra 12v lead from alternator to battery
Optima yellow top battery
Power Mod list for EJ22T:
Absolutely freakin nothing.
Power Leeches:
Original Exhaust with 116,000 miles -->
Extra back pressure (torque peak is a couple hundred RPM late)
Notes: Graph starts where it does because that is where the NA dyno graph started. And if you want a percentile comparison, from the start of the NA graph to the end of the Turbo graph.... the turbo has 11% more area under the torque curve.
