Ok, well here it is, the "Shift like a pro" guideline by BAC5.2.
Now, no one here took notice of my Bolster mod (which, I'm happy to report, still satisfies me to this day... haters), but this is sure to win a few hearts.
There's a few oddities about the BC and it's shifter. First of all, our shifters house the "fork" portion and the WRX shifter features the "knuckle" portion. It's the exact opposite. The only other, recent generation car that shares OUR shifter setup is the 1993 Impreza. I've seen a FEW short-shifters out there for the 93 Impreza, but none that look very good.
You will also notice (maybe) in the picture (Fig. 1), that the WRX shifter is only about .5" shorter than stock. The lay-back angle is the same for both. The mounting to the actual shift linkage, is in about the same place. The lower ball portion of the WRX shifter is plastic, and smaller than the Turbo Legacy's steel ball. The ball is held in place with a hollow pin. It IS possible to swap them over, but in reality, I don't see any advantage to swapping to the WRX lever. The WRX lever is filled with a motor-mount type of shock absorbant material. You can flex the shifter in the "goo" in your hand. Ours is straight steel, pretty stiff. It's also lighter, but that's a gram-counter thing...
When swapping to the WRX shifter, you would need to swap the lower ball, and you would also need to do 1 of 2 things. Swap the linkage itself, or simply make an adapter to connect to the stock knuckle. I don't think it's worth it.
(Fig. 1)
http://www.thawa.net/bac52/Shifter/shifters.JPG
Now with that little bit of information under our belts, here's the first step I took in my quest for a better shift feel.
As some of you know (or at least do now), I have a Greddy Trust shift knob (stock one wore out. Fig. 2). It was, obviously, designed for the GD, and with the stock amount of threading on the shift lever, it sat about 1.5" higher than it should have. I also had a pimped out shifter boot that I got from Art back in the day (First mod, see what you started Art
Cutting more threads allowed my shift knob to sit lower on the lever, and as a bonus, allowed me the room to snug the shift boot to the knob (using that nut to hold it in place). The collar I had was designed to screw in place of the round bottom portion of a Momo shift knob. As soon as this was done, the shift throw felt solid. It was kinda nice, sort of clunked into gear. One step closer to the desired effect. Since the dimensions are the same, I would suspect that you could even cut about 3/4 of an inch off of the stock knob and die more threads on, and acheive the same feel as the stock WRX shifter.
(Fig. 2)
http://www.thawa.net/bac52/Coilovers/Shifter.jpg
Total time: ~20 minutes.
Now, I was having a lot of gear grinding going into 3rd gear. Matt can attest to this. First thing I did to try and remedy this was Group-N engine and tranny mounts. This was at the advice of Brat4by4. It helped a little, and I could DEFINATELY feel a BIG difference when I swapped to those mounts, but it was still a problem. There was a noticeable NVH increase, so for those considering it, know that it is noticeable. I don't mind NVH, not in the least.
So what to do?
Well, I was speaking with Vikash, and decided that a shifter bushing would be a good upgrade. Problem: No one makes shifter bushings for old style cars. Everything is for the 94+ GC, which shares the shift lever design with the GD. So what did I do? Got an Energy Suspension bushing for a GD. Part number is 1170 (Fig. 3).
It wouldn't fit immediately, but that was to be expected. Out comes the knife.
I trimmed the "bubble" edge of the bushing, lubed it with Lithium grease, and made a press out of plastic and a C-clamp. It took some doing, but I got it in. It fits (Fig. 4)
Reinstalled the shift linkage, and drove it. Shifted much better. I felt like I had a more direct link to the transmission.
To drop the shift linkage, it's pretty easy. 3 bolts. Remove the center consoles, unscrew the steel plate around the shifter, unbolt the shift lever from the linkage. Pull up the rubber boot and remove the snap ring with some snap-ring pliers. Pull the shift lever out of the housing and remove the plastic bushing part. Crawl under the car, unbolt the 12mm bolt on the transmission (there is a plate with a spring on it, guess what that spring is? That's the tension spring to keep the shifter in the 3/4 neutral position). Remove the 2 12mm bolts directly above the drive shaft, just aft of the shifter. Can't miss it. The one on the passenger side is pretty difficult to reach, so I got that one from inside the car with an extension on a ratchet.
Drop the linkage, push out the flimsy stock bushing, install the new one like I mentioned above, and bolt it all back together. Pretty straight forward.
(Fig. 3)
http://www.thawa.net/bac52/Shifter/bushing2.JPG
(Fig. 4)
http://www.thawa.net/bac52/Shifter/bushing1.JPG
Total Time: ~1 hour including modding the bushing.
But there is a problem with the stock setup. This is the most impractical problem as well, as I have some resources that others may not.
The stock REAR shifter bushing is, well, shitty. This is an often neglected bushing in all markets I have seen (WRX included). The stock bushing just allows for a LOT of movement. (Fig. 5)
Want to feel movement? Put the car in 4th gear, and pull the lever towards you. Feel the squishiness? Wiggle the lever side to side. Again, the squishiness?
So, I decided to make my own bushing.
I have access to a super high density polycarbonate plastic. This stuff is STRONG. I used it in a record setting concrete beam in high school. I used it to press the bushing in on the front bushing. I've used it as a plate to jack the car up, and it comes away without a mark. It's some freak stuff, but it's awesome. I made a custom motor mount for a direct-drive remote control boat out of the stuff. Neat.
So I did the easiest thing I could think of. Cut a peice to fit where the stock bushing was. Drilled a .5" hole in the center of the bushing, and then cut it in half. Slid it into the stock bracket (after cutting out the stock rubber bushing with my bandsaw), and drilled a hole through it (Fig. 6). I used 2, 1/4 x 2" bolts to hold the new bushing halfs in place (Fig. 7).
(Fig. 5)
http://www.thawa.net/bac52/Shifter/rear%20bushing2.JPG
(Fig. 6)
http://www.thawa.net/bac52/Shifter/modd ... shing1.JPG
(Fig. 7)
http://www.thawa.net/bac52/Shifter/modd ... shing2.JPG
Bolted it all back up.... And was disappointed.
On the bench (or jackstands). I didn't feel any difference. It felt exactly as it did before.
Then I went to move the car.
I slipped it into first, and smirked. *click* right into gear.
Started going, clutch in, *click* 2nd. Clutch in, *click* 3rd.
Not only did the car click through the gears, but it also inspired a LOT more confidence. I felt like I could shift faster, and with more solidity, and less effort. Crisp, short throws, and the shifter sucking into gear. I found myself doing a heel-toe 4th to 2nd shift and not even noticing. Things just felt MUCH more connected.
It felt "right" and how I wanted. Wiggle the lever in gear, and it's snugness rivals the S2000's. Still some wiggle (about .5") likely from the shift forks in the tranny, but significantly less than stock. The new rear bushing DID increase NVH slightly. Vibration is increased due to the severe reduction in compliance over the stock bushing, but it's worth it. All grinding of 3rd gear is gone.
Total time: ~ 2.5 hours including custom fabrication and a trip to Home Depot for bolts and drill bits.
The final "Shift like a pro" mod is easy. Redline 75W90NS GL-5 transmission fluid. This is icing on the cake. It feels like you are shifting into a stick of butter. SOOOOO smooth. Expensive stuff (~8 a quart from www.OGRacing.com ), but it was worth every penny.
So, there you have it folks. My car shifts amazingly well now, and it feels like a much more solid setup.
The total shifter re-model cost me a grand total of $25 (not including the fluid). ~10 for the front bushing. ~5 for the thread die. ~10 for the bolts and drill bits for the rear bushing.
I hope someone finds this guide to be helpful. If there is anything that you guys need explained or elaborated on, let me know and I will be happy to answer any questions you guys have.
