MAF Adapter,
MAF Adapter,
Hey all, im new to tis site and ive recently became a proud owner of a 1993 Subaru Legacy L series, and i have been doing all i can to it and i baught and aftermarket air intake that would fit it but it didnt come with an MAF adapter for the filter to the sensor,
Can anyone help me find a MAF adpator???
-Thanks-
-Thanks-
93 Legacy L
Black hood, Custom Exhaust, Crank case breather, Performence Intake, stock rims, Custom Stereo System.
The general consensous is that anything but the stock airbox hurts performance. If it's sound you're after remove the snorkus. What is a crank case breather?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
BAC5.2
Probably one of those little filters you can stuff on the end of one of your PCV lines.
You've surely seen them around, and just aren't making the connection.
They don't really do anything for performance.
Teague's auto sells the maf adapters www.boxer4racing.com
Like others have mentioned, the stock intake box typically is pretty good to stick with.
I've made a custom one from a generic adapter. Made it back in 97
BAC5.2
BAC5.2
Where are you going to set it up? The line from the Crank Case fork to the intake?
I'm just going to make a catch can. I see no need to pay $80 for something I can make myself, and have it look just as good.
Thanks Legacy777, ur post helped me out and that is all i need to get that intake to fit...Does an after market intake really hurt the performence of the subaru tho???
93 Legacy L
The open intakes do help top end performance, but can also reduce low-end torque. I didn't really notice this until I put the stock airbox back on.
Drive around with the intake, see how you like it, then put the stock airbox back on, and see if you notice a difference.
