Got my TMIC on today. Saab set up
Front, Top, Air, Water.
GizMo22t
Post by GizMo22t »
It is about 6:00pm and I have been working on the IC for about Three hours or so. I purchsed the IC for $25 form a guy I know in Ft. Collins. After much deliberation I decided on how I could get the IC to work. There was some cutting and JB Welding but not much. The inlet had to be cut and turned around 180Degrees. I got the pipe cut and the JB weld on last night so I could get it done today. I do have a picture of the finished job but I need someone to host. The only thing I still have to figure out is how I am going to mount the BOV. Total cost of the project was around $50 or so. That is only because of the low cost of the IC. If you have any questions feel free to ask
Mo
93touring wagon
JasonGrahn
Post by JasonGrahn »
aHHHH!!! JB WELD?!?! ON A PRESSURIZED PIECE?
Have fun!
-Jason Grahn
GizMo22t
Post by GizMo22t »
JB weld worked on my buddies BOV and he was pushing 20psi so I think that I'll be good with 10psi
Mo
93touring wagon
JasonGrahn
To each their own.
Just heed the immortal words...
Go For It!
-Jason Grahn
magicmike
Post by magicmike »
stupid question......whats a JB weld?
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
JasonGrahn
http://www.jbweld.net/
good for temp fixes IMO.
-Jason Grahn
91White-T
Post by 91White-T »
I've had a piece on my saab IC JB welded since last august and pushing upwards of 15psi.... you should be fine.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Properly applied, JB-Weld is supposed to have a tensile strength on the order of 4,000 psi. If you do it right, it's almost as good as a good weld with decent rod.
Fernely
Post by Fernely »
I will post up a pic of my Saab IC with my temporary pipe and how I pu the Recerculating valve in. I should have it up some time this afternoon.
We have two seasons in Miami, Hot and Hotter!
GizMo22t
Post by GizMo22t »
Ok thanks that should be helpful. I still need someone to host the pic's I have.
Mo
93touring wagon
morgie
Post by morgie »
send them to me, i'll host them
nicvallee@sympatico.ca .just make sure your mail dont exceed 3mb and it will be fine :)
morgie
'98 4Runner V6 Manual 4x4.
GizMo22t wrote:Ok thanks that should be helpful. I still need someone to host the pic's I have.
I've emailed you the links to post for your pics.
GizMo22t
Post by GizMo22t »
Josh: I'm sorry can you E-Mail me that link again I must have deleted the mail by accident. Thanks
Mo
93touring wagon
GizMo22t
Post by GizMo22t »
Thanks Josh Here is the pic if you didn't click on the link.
Mo
93touring wagon
91White-T
Post by 91White-T »
I've got the exact same setup, and just to let you know, make sure that the IC clears the coolant tank lines on the back. Mine didnt and broke off in a matter of weeks, especially if the coolant tank is older and more brittle.
GizMo22t
Post by GizMo22t »
Thanks for the Info I'll keep an eye out. Do you have any problems of it rubbing on the fire wall?
Mo
93touring wagon
91White-T
Post by 91White-T »
It actually rests right up against the firewall, the coolant thing is the only problem its caused, other than that its a pretty damn good fit...
Fernely
Post by Fernely »
OK i was real busy last week, my wife had our second baby a beautiful girl. Here is the shot of my temporary set up. I need to get to the custom shop I use and get the proper pipes bent. I'll post more about it in a few weeks.
LegacyT
Post by LegacyT »
GizMo22t:
How does the engine run without the recirc-valve plumbed up?
Mark,
-K-
Post by -K- »
You should unbolt the coolant tank and turn it kinda sideways. Maybe
zip-tie it out of the way, then it won't break.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
LegacyT
Post by LegacyT »
How did you clear the brake booster reservior? Also did you cut the outlet end of the intercooler off - or just place it into the throttle body? And finally how did you clear the lines coming out of the coolant tank?
Thanks,
Mark
