Plastic Engine Cover Removal
Nomake Wan
Post by Nomake Wan »
Alright, I asked this same question to Legacy777 a while ago on NASIOC, but the damn thing just refuses to come off through brute force pulling.
So what I want to know from all of you is this: is there any way to remove this cover without damaging it? I'd like to get under it to clean and stuff, but I don't want to break it; I like how it looks and intend to keep it there.
Anybody?
[url=http://www.cardomain.com/ride/762395]1990 Legacy L (Sold)[/url]
[url=http://www.cardomain.com/ride/2564067]1992 SVX LS-L[/url]
[quote="LaureltheQueen"]I like my automatic, it's fun to drink coffee and smoke civics at the same time[/quote]
scottzg
Post by scottzg »
pull harder, ya weenie!
I would say more than half (probably much more) of the plastic coil covers I've seen on first-generation Legacies have a crack over at least one of the four mounting tabs.
You could probably lessen the chance of damage by warming the engine up first, so the polymers will be more flexible rather than brittle.
mikec
Post by mikec »
I agree with Vikash. But yeah, in the end all you can do is pull. You might be able to get a screwdriver underneath it enough to use that as leverage.
I've always just pulled tho.
Nomake Wan
Warming up the engine. Should've thought of that.
And mine's just being bitchy. >.>; I'll warm 'er up and see what happens. Thanks, guys.
THAWA
Post by THAWA »
You just have to put a little man behind it. Start at one of the corners and rip that suckah off. If you break it go buy another one.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Another thing you can try is taking some spray lubricant and the little red extender and try and spray the rubber where the plastic from the cover comes together. That may help.
IronMonkeyL255
Post by IronMonkeyL255 »
Mine cracked over the upper-lefthand thing.
I just took the rubber piece out of that one and start on the other side now.
How much is a replacement for that?
I can't find ANY good junkyards around, so that's not an option.
Rio Red '91 Legacy SS
91White-T
Post by 91White-T »
Weight reduction, ditch the useless thing. :)
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
I have an extra one I don't need.
