What size wheels are those? And your getting 33 with a turbo AWD?
I've gotten 29 with my SS on a highway drive at 75-80mph over a mountain pass.
With the right driving style and all highway I bet 33 is possible. Used to get 31 in my '96 Legacy all the time driving to work on the freeway at 65mph and about 80/20 highway/city mileage.
Thesubielover
Yeah, I managed to pinch out over 300 miles out of a tank at one point too
i get about 200-215 a tank
Holy crap CJ! I just started getting right over 300 per tank before the low fuel light comes on. I'm about 4k miles since the engine was rebuild, at 0-3k miles it was getting 215-230 per tank. That's with mixed driving, boosting a lot, and the cheapest premium I can find, lol. Ej20g with td04 and JDM gearbox with shitty 5th gear.cj91legss wrote:i get about 200-215 a tank
hmm maybe its time for a rebuild...
My red one was rebuilt and it was getting only
20-21mpg with easy driving. Just changed out the
coolant temperature sensor the other day. Letting
a friend borrow it now, but we'll see if it alleviates
the issue.
the issue.
maria24017
Where is the low fuel light located?? And does anyone know how to change the bulb?? Mine doesn't work
1990 Subaru Legacy L sedan 2.2L 4 cyl AWD automatic 122,500
The worst day of your life only lasted 24 hours
I could get over 300 easily on a tank, but I usually fill up at about 250-270 miles on a tank just because I don't like to run it too low.
The low fuel light is a square to the bottom and slightly to the left of the fuel guage. It lights up orange. If you pull the gauge cluster you should be able to replace the bulb.
what he said^^^SILINC3R wrote:What size wheels are those?
also whats the offset?
It's easier if you pull the bulbs in that area and hold theAlphius wrote:I could get over 300 easily on a tank, but I usually fill up at about 250-270 miles on a tank just because I don't like to run it too low.
cluster up to a light. But then again you could just see
which bulbs are blown when you pull them, I just think
it's fun
I just don't see getting 5 more MPG like you're talking about. That'd be filling up at 300 miles and only putting 10.35 gallons in. Well unless I did 100% highway driving, drafted everyone and used neutral while going down hill.Alphius wrote:I could get over 300 easily on a tank, but I usually fill up at about 250-270 miles on a tank just because I don't like to run it too low.
A spoiler won't necessarily get you worse mileage. It depends on the airflow/vehicle speed. The spoiler could help airflow reattachment off the roof (especially where the trunks on these are pretty low) on the sedan and angled down slightly on the wagon could reduce wake drag by easing the transition of the airflow off the roof (you'd need a windtunnel or at least a good CFD program to nail down optimal angle at a chosen speed). IMO, we're not talking significant differences outside the basic +/- of general variable daily traffic conditions even over the same route, but the potential benefit is there nevertheless.
Slapped these wheels on. Old wheels looked good, but function > form
And these wheels are freakin sweet
And I love hearing that people care more
about function than form. We may make it
out of the ricer crisis with some dignity left
after all
You're welcome, future kids.
after all
The RevTronix chip runs the engine around 15.2:1 at cruise which drastically increases fuel mileage over a stock ECU's tune. I get better gas mileage than any other turbo Legacy I've owned before. Half a point leaner makes a big difference.mike-tracy wrote:I just don't see getting 5 more MPG like you're talking about. That'd be filling up at 300 miles and only putting 10.35 gallons in. Well unless I did 100% highway driving, drafted everyone and used neutral while going down hill.Alphius wrote:I could get over 300 easily on a tank, but I usually fill up at about 250-270 miles on a tank just because I don't like to run it too low.
Pulled and pressure washed the sedan carpet yesterday, helped it finish drying today with a heat gun. Still haven't put it in cause the padding on the bottom hasn't dried totally yet.
Danny
OK well it wasn't today but it was a couple days ago... I was doin trail work up in the mountains which involved a few miles of rugged access roads far better suited for trucks than cars. I was mob'n pretty good while mostly avoiding potholes and washboard. I drove back down at the end of the day hoping that the 65mph+ shakes hadn't got any worse. A miracle happened! The vibration has been significantly reduced! WTF? Any ideas how this happened? I was originally thinking that its was just a wheel out of balance.... I'm not complaining though!
Could be mud on the inside of the wheels. It'll
make your car wobble like crazy. When you
get home see if there's mud and if there is
spray it all out and it should go back to normal.
Yup, was probably mud. I'd suggest washing the wheels out anyway to get rid of any residual mud.
Put my spare wheel on to see how the Fozz wheels look in gold. So far I'm really liking gold but I'm trying black later and gunmetal after that.
What do you guys think of the gold vs black or gunmetal?
Danny
A darker gunmetal would look good on that car, in my
opinion. What happened to all the lights?
The front light bar is still there and the roof lights are normally in the trunk since the make a pretty big difference in gas mileage.
Danny
As for what I've done today, it was last night actually. Changed out both front CV axles. No more clickety clickety clickety. Much improved!
CAV3MAN227
-Well I have fallen victim to seafoam. I'm a believer now. Put it in the car today thru the pcv system and what a difference the car has made. better in every way!
-Joe
-Joe
