Yes, i'll have to go buy some tomorrow sometime.
Update, just pulled my old FCD off, and it looks like the capacitor blew up. I'm going to solder a new one on and see if it's still salvageable. If it is, one of these will be for sale.
northcoast
Post by northcoast »
What does it do?
Lifted 91 LS Wagon : SOLD
87 GL-10 Turbo : SOLD
Lifted 97 Impreza OBS
98 Impreza OBS RallyX / DD
It clamps the output voltage on the map sensor at 4.7-9v so that the ecu doesn't see 5 volts from the map sensor. When the map sensor on a turbo legacy sees more than 12.7lbs (5v) boost, it enables fuel cut therefor killing the motor. In order to run more boost on a turbo legacy ecu, you need to have a fuel cut defender.
And the old one is still toast.
northcoast
Soaking wet but the drive shaft is back in. No vibrations!! Nice to have 4WD again. 4 Low with a Franken motor kicks @$$.
4 low? You got a gl trans or something?
northcoast
Yep.
SUBYLUV871
Post by SUBYLUV871 »
this week i pulled the motor on my gt and did a clutch and flywheel, water pump timming belt and pullys and oil pan and cam seals. put the motor back in and she a happ suby now. motor out in 1 hour and motor back in in 1.5. not hard at all. it was my first time. all ready for the oregon winter.
1998 legacy l wagon
1988 ford ranger prerunner (my baby
Nicely done for your first time! I could probably get the motor out in 45 mins and I've done it a couple times.
northcoast
Reminds me... I need to pick up some 14's for the next time I pull the motor. My 2.5 ton hoist doesn't lift it high enough now and I have to wrestle with the motor to get it out of the engine bay.
SUBYLUV871
the first time i did it was last saturday and i put the main seal in too far. and after i put the motor back in and ran for about 20 seconds oil all over the floor. thats a heart breaker, out it came to fix that then right back in for the second time . good experiance and it saved me a chunk of money. ready to run past 300k
1998 legacy l wagon
SUBYLUV871
just put in an oreder for 1.5 lowering springs. now to fix my sloppy shifter and do the wrx shifter swap.
1998 legacy l wagon
originalcyn
Post by originalcyn »
Calipers back from the powdercoater, pictures in brake journal.
Kijan
1993 Legacy LS | PBM 227
northcoast
Knock sensor and skid plate.
turbo970
Post by turbo970 »
heard my rebuilt motor run today. now needs a tps. hoping to have it back monday or tuesday
originalcyn
Went to pick up a hood scoop from 2.2TLegacy. Then picked up some engine clear coat to hit the decals on my calipers.
Kijan
Swapped my bad heater control out for a bad heater control. Then proceeded to cuss....
Alphius
Post by Alphius »
cj91legss wrote:Swapped my bad heater control out for a bad heater control. Then proceeded to cuss....
Maybe it isn't your heater control? :-D
That's possible, but who knows. I have a toggle switch to turn the blower motor on.
Anyways, today I finally did my rear driver's side wheel bearing, MUCH MUCH better. Also got rid of the rear ABS sensors and tightened up my e brake lines. Very satisfied now.
Ended up replacing all the hardlines on my garage compressor too, no more leaks in the lines from the pump to the tank. Contemplating mounting my ecu correctly. Right now my spare is zip tied to the column. seeing as i have 2 working ecus now, i may sell one.
Went from a turbo 3-port charcoal canister to a 2-port. My ej20g ecu doesn't control the purge control solenoid, so by removing all that stuff and simplifying, as well as putting clamps on almost all my vacuum hoses, I was able to bring the vacuum at idle to 20 from a varying 12-16. Butt dyno says the engine revs smoother and turbo spools slightly faster, as well as less boost spiking.
Hmmmm....Do you think mine controls it? I've been thinking about ditching the charcoal canister all together again. Don't like it. Takes up space and looks ugly and doesn't seem to make much, if any difference whatsoever.
Alphius
Post by Alphius »
Any EJ20G ECU doesn't have logic for controlling the purge solenoid.
mike-tracy wrote:Went from a turbo 3-port charcoal canister to a 2-port. My ej20g ecu doesn't control the purge control solenoid, so by removing all that stuff and simplifying, as well as putting clamps on almost all my vacuum hoses, I was able to bring the vacuum at idle to 20 from a varying 12-16. Butt dyno says the engine revs smoother and turbo spools slightly faster, as well as less boost spiking.
Mike, so how do you have the charcoal canister hooked up? Is it just collecting the vapors from the gas tank and not being drawn into the engine to burn or are you running an auxiliary type purge setup?
Hi Josh, it is connected in the same manner as the N/A's (and ej20g), with a check valve on the larger port on the canister.
Not my car, but here's what I'm talking about (an ej20g setup):
Is that a 20g swapped loyale?
