Those just look like part of the grill and are kind of like "eye lid" type things for the head lights.
Danny-G
Post by Danny-G »
Found my leak, top of the windshield where the rust is. I hate rust..
Danny
alexandermf
Post by alexandermf »
Decided to finally paint our garnishes and it turned out pretty good!
dillonr92
Post by dillonr92 »
Plasti-dipped my entire roof to seal my sunroof. Cant see out of it but when summer comes back I can peel it off and open it again. Plasti-dip is the shit
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
randomiam
Post by randomiam »
replaced my front stock rotors/pads.. Guess I'll put the brake upgrade off a bit longer.
Subaru-less
dankberries
Post by dankberries »
Cylinder leak down test . Video:
http://youtu.be/iDpNusbxcgs
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Danny-G
Post by Danny-G »
alexandermf wrote: Image
Reminds me of when I did mine, this makes our cars look even more alike haha. Considering a light bar sometime soon? xD
Danny
dillonr92
Post by dillonr92 »
Painted rims,rotors and calipers black, spoiler black. Reinstalled the spoiler. Finished the ground mod.wiring in door lights and more 12v power outlets Today.... Image
I cleaned the interior & washed the exterior of the Impreza and washed the exterior of the Legacy this weekend. Of course it rained after washing the cars. The Lego stayed dry in the garage though :)
94EJ22
Post by 94EJ22 »
In the last week I plasti-dipped my grill and windshield wipers, changed my oil, got an OBX crank pulley installed with new Gates drive belts, got new OEM front lower ball joints installed, and installed a new Denso alternator (mine was dying out).
1994 Subaru Legacy L Winestone Pearl
Danny-G
Post by Danny-G »
Alternator went out, already got it replaced.
Danny
92ColoradoTurbo
Post by 92ColoradoTurbo »
Painted my black trim+chrome around my car with semi-gloss black spray paint. Hope it holds up through the winter.
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
free5ty1e
Post by free5ty1e »
Got my timing belt & seal replacement operation well underway today (finally!)
Cracked my crank pulley bolt loose with the starter and a breaker bar resting on the car:
As far as I could tell, the crank pulley bolt didn't shear from this action. (please feel free to check out the detail photos in the linked post below to see the bolt and the bolt hole in case you think you can help identify if this is not the case)
Bonus, my non-impact 22mm socket did not crack or chip at all during this process as I thought it might!
Anyway...long story short, what I thought would work (in my head planning to use 5th gear and a friend standing on the brakes to allow me to crack loose the cam pulley bolts before timing belt removal) won't (automatic transmission) :o
So... I reckon I could use the same starter trick to crack loose the cam pulley bolts:
^^^ .....no?
Would this be a terrible, horrible idea? And why? They aren't reverse-threaded or anything ridiculously dumb like that, are they? Can I do this?
Link to detail post
-Chris
91SS 4EAT stock, 200k mi
James614
Post by James614 »
Finally finished all the ECU related wiring changes to run my rob tune ECU on my EJ20G using the stock harness. I REALLY wish I had just did a 5spd swap and rob tune on the EJ22T with the 2ch ignition converter. Would have been sooooooooooo much easier. I already had everything needed to do it that way... but oh well, its almost done now.
CAV3MAN227
Post by CAV3MAN227 »
-Changed my oil at work last week. Was bout time I did that!
-Joe
dankberries
Put an additional 150miles on me engine today. Now at 550miles, no smoke, no timing issues, and drives good. Installed the boost controller and got it to 15lbs for now. Waxed the car for an additional 5hp. Feels and looks tits.
90 Nissan 240sx 2jz
Danny-G
Post by Danny-G »
Swapped the 6.5 inch front speakers for 5.25 inch ones. The 6.5 inch ones wouldn't clear the windows.
Danny
94EJ22
Post by 94EJ22 »
Installed a Yakima Roof Rack
James614
Post by James614 »
Replaced all of the bolts and studs on my TD05. Didn't take that long, but not very fun doing it with the Turbo on the car. Car is getting VERY close to being able to be fired up!
dillonr92
Post by dillonr92 »
Did an oil change and switched to full synthetic from semi synth. Now for the rest of the tune up on friday
Danny-G
Post by Danny-G »
Replaced the broken power antenna with a normal non power one.
Danny
originalcyn
Post by originalcyn »
94EJ22 wrote:Installed a Yakima Roof Rack
Is that the NA bumper for post face lift? What did you use for fog lights?
Kijan
1993 Legacy LS | PBM 227
Danny-G
Post by Danny-G »
He has the OEM fog lights. I'm pretty jealous
Danny
CAV3MAN227
-Raced my car in a SCCA event at PPIR (Pikes Peak International Raceway) on Sunday. So much fun!
-Joe
originalcyn
Danny-G wrote:He has the OEM fog lights. I'm pretty jealous
I was going to say that they fit very well.
Danny, knowing your affinity for lights, i'm surprised you don't have a set or two.
Kijan
