16 year old's legacy
tris91ricer
- Title Whore
dropdfocus
I have to get those for my women when I overheat them. I keep a few of 'em in stock next to the ice cube trays and frozen pizzas.
Nategreat923
thanks, ill keep that in mind next time I use those (serious not sarcasm)555BCTurbo wrote:Nategreat923 wrote:i asked my friend to show me what it would look like with an intercooler, so he messed with it a lil, so yeah its photochop stuff
Fixed some stuff for you
i have a question. my friend said i have a EJ22 because my soob is manny, but its not turboed so i didnt think it was.
NaTeWoOt
dropdfocus
They were all 2.2 motors in the Legacy from '90-'94 reguardless if it was manual or auto, but if it's a turbo model, then it's an EJ22T. If it's N/A (nat. aspirated) then it's an EJ22.
EJ18's showed up in low end Imprezas, and EJ25's didn't show up in the Legacy until '96.
Jason
Nategreat923
ohhhhh, thanks a lot. my friend thought it was a ej20.dropdfocus wrote:They were all 2.2 motors in the Legacy from '90-'94 reguardless if it was manual or auto, but if it's a turbo model, then it's an EJ22T. If it's N/A (nat. aspirated) then it's an EJ22.
this will be a pain in the butt question, and ive tried lookin in other posts but im a noob, how hard and expensive would it to turbo it. like whats the minimum it would be to turbo it with the smallest turbo? thanks in advance
NaTeWoOt
(someone's gonna slap you w/ the search stick)Nategreat923 wrote:this will be a pain in the butt question, and ive tried lookin in other posts but im a noob, how hard and expensive would it to turbo it. like whats the minimum it would be to turbo it with the smallest turbo? thanks in advance
dropdfocus
Well...
You'd be changing out quite a bit to do it.
- different ECU
- different full exhaust
- different intake manifold
- different intake tubing
- different injectors (possibly optional depending on turbo size)
- turbo
- intercooler (again optional, but highly recommended)
- many misc. hoses & additional odds & ends
All said & done, you could be selective in what you pay & where you get it from and likely pay $1k or less.
Picking up a used VF-11 (stock Legacy turbo) and other tid bits wouldn't be too hard.
Use the search function and look up turbo swap, or engine swap. Browse the topic's content and remember to take everything with a grain of salt. Everyone has a different take or opinion on situations around here.
- different ECU
- turbo
Jason
dropdfocus
BTW, look just below and to the right of your power steering res. and you'll see a casting area that shows EJ22 right on the block. The EJ20 only showed up in the JDM Imprezas and the early US market WRX's.
Jason
Nategreat923
Ohhhh. thats exactly what I was looking for. Thanks a lottttt.dropdfocus wrote:Well...
- different ECU
- turbo
and IMO i like front mount intercoolers better then top
NaTeWoOt
dropdfocus
Until you go with a larger turbo (which requires many more supporting mods, like fuel delivery upgrades & such) you'd lose HP with a front mount vs. the top mount. The longer length of piping to the front & such would cause longer spool up times. This would take you longer to achieve the desired effect you are going for. The top mount being right next to the turbo allows for shorter spool up time. Basically you hit full boost much quicker.
Sorry, the front mount might look cooler, but it isn't the most desirable item when running stock equipment.
Jason
Nategreat923
well, they say you learn new things every day. thanks for the info. yeah, i just want a small turbo (if i really do even want one) for a little fun, because this is my car for the mountain (snowboarding with friends and such) so it wouldn't be a big turbo, I'll probably keep it NA, but I just might turbo itdropdfocus wrote:Until you go with a larger turbo (which requires many more supporting mods, like fuel delivery upgrades & such) you'd lose HP with a front mount vs. the top mount. The longer length of piping to the front & such would cause longer spool up times. This would take you longer to achieve the desired effect you are going for. The top mount being right next to the turbo allows for shorter spool up time. Basically you hit full boost much quicker.
NaTeWoOt
dropdfocus
tris91ricer
- Title Whore
Nate,
I'll have some stuff you would need for a turbo swap coming up in the next few months. Harness, ECU, exh, heads and intake mani, and tdo04 with TMIC. Basically, everything you'd need except the shortblock. I'll keep you posted.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
you know you could always just buy an ej20g with a 5m/t off of ebay for about $1k too.
my friend and i swapped one into his 95 Impreza L. It was pretty straight forward if you have a basic idea of what you're doing. The wiring took us the longest to do, but everything was done in about two weeks and for $1k, that's the biggest performance increase you can get lol.
he went from like 115hp to 240hp and 4.44 gears lol.
Nategreat923
Nategreat923
Nategreat923
dropdfocus
And for the record... I believe the NAs were an EJ22E while the turbos were EJ22Ts (minus the (s) for non plural use, aka singular form, so its an EJ22T)... lol
dropdfocus
Nategreat923
