CFK's 92 SS Daily/Project (Video & Pics added Mar/31)
CFK
Re: CFK's 92 SS Daily/Project
Post by CFK »
5 Month's Later Update : Frames Bent, Still Depressed :smt022
Cracked some ribs snowboarding, Hurt way to much to sand, so the project was put on hold yet again. Built a mini Booth and Tried sandblasting wheels. Way to time consuming, gave up, took them to a U-Blast Place.
I sidetrack easily, projects include :
A Sandblasting Booth :
Gave that up and took them somewhere else. Way to time consuming. Need at least a 7.5HP Compressor.
The Wheel Collection, Minus a Second set of Speedline Pero-R's ( FOR SALE )
They I Built a Powdercoating Oven :
Began Powdercoating :
Got the wife's Professionally done :
First one turned out a little Crinkly, but OK. Gold with Satin Clear :
Powdercoated the Centers Gold, with Gloss Clear. Bolts Olive Drab & Got the Lips Polished and I coated them with Sharkhide protectant :
Had some Insulation left over from the Oven, decided to do the Garage Door :
Then I wanted to get my chairlift Modified and hung. Chopped it, welded it, hung it. Porch Swing :
Ok, Enough time wasted. Back to the Subie. NOS OEM Fender. Car still Bent :smt022
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
Did the car come with a bent frame rail, or did I miss where it happened?
CFK
Post by CFK »
Ya still haven't even got it on the road yet, it came with a damaged fender. The door would contact it, you can see it in the very first pictures. Never really thought anything of it then . It appears someone has already tried to straighten it and failed, I might Hilti a hook to the ground and try it myself.
Build Thread : HERE
CFK
Post by CFK »
Finally Got him in the Booth after much trouble and frustration :!:
Very Stoked on the colour, Just can't decide if I liked it better Matte or with clear !!!
Build Thread : HERE
That's an interesting color. I kind of like it in the matte finish.
Man my phone didn't do the pic justice lol.
CFK
Post by CFK »
Thanks Guys, I like the matte, but think it kind of makes it look Ghetto. Nobody realizes that you actually have to pay more $ for a flattening agent :!: I like it on high end cars though.
Only had time for 2 layers of clear cause they were kicking us out of the booth, turned out a little rough, gonna wait three weeks and wetsand, then re-clear :(
Oh well, gotta paint all the trim and powdercoat the set of Prodrive Pero-R's !!!
Build Thread : HERE
CFK, you wanna direct me towards a reasonably priced paint supplier since you have experience? Or come paint my car and i'll buy you some beer :P
CFK
Post by CFK »
I hardly have experience LOL, I did the bodywork and sprayed the high build. Masked. My friend actually sprayed the car, it was his 6th full car and we were under pressure with the time. If I sprayed it we would have ran out of time for sure and would look alot worse :-D
I actually purchased my paint through KMS Tools, didn't really try to go straight to the supplier. It was PPG Omni, lower grade paint. I think Deltron is above it. Pretty thin , barely reduced it. It was $206 for the gallon of Base I believe. but with all the materials including sandpaper , filler, etc, I probably spent around $1400, but have quite a bit of leftovers. Only thing we ran out of was the clear cause I had used some to spray the wife's wheels.
Just do some research and shop around. If you want me to do it, it will probably take about 2 years :roll: :!:
Build Thread : HERE
CAV3MAN227
Post by CAV3MAN227 »
-Awesome. You got your car painted in the color I want mine in. Build is great. Nice job on welding in the hood scoop.
-Joe
CFK
Post by CFK »
Thanks. Love the Colour :!:
I actually did a terrible job welding the hood the first time. Can't Weld them , to thin.
I used a Weldless kit from eastwood. Worked awesome.
Build Thread : HERE
CFK
Post by CFK »
Waited to cure, wet sanded. Painted all the innards and im gonna re-clear it hopefully this weekend !
Build Thread : HERE
Thesubielover
Re: CFK's 92 SS Daily/Project (updated Jan/23/13
Post by Thesubielover »
Looks good!
Now that is really something!
Thesubielover
I like the wheel dolly you have under each wheel. Work smarter, not harder.
93legacylsleeper
Post by 93legacylsleeper »
Looking Rad!! Can't wait to see it all done!!
NightOwl
Post by NightOwl »
CFK wrote:No Doubt :smt073
Sorry about the late response, working graveyards and just got back from Jamaica.
I actually overheated and warped the hood by welding it in. Then I tried to fix the warpage/ oil canning by using a method called " heatshrinking " . It didn't work as I ended up chasing the low spot right over the hood line, therefore completely ruining the hood :smt022
I haven't been able to find another GC 2.5 RS hood so I will probably be using a BD Legacy GT scoop instead for round 2 . In the meanwhile I will probably just fill the existing hood and just prime it, so at least I can get the thing painted and on the road.
Like So:
I like the clean flush look, but I don't think the scoop opening is as wide . Im undecided, all I know is that there is a guy in the neighborhood that has a GT Scoop and is cheaper than the $150 that the local wrecker wants for a damaged 2.5 RS Scoop :roll:
Whos car is this and where can i see more pictures of it?! its awesome
93legacylsleeper
This forum is about CFK's legacy. Haha kidding the red wagon belongs to Mikeymeyagi I may have spelled it wrong but he is a member on here.
CFK
Post by CFK »
No Doubt , I'm absolutely appalled !!! What couldn't make a nice comment about my Car !!!! :smt013
Ok , I'm over it :)
But looking at that grill I wish I modded mine and cut the center out. Painted it last night though :!:
I actually got 2 , painted 1 coloured and 1 black. Pretty sure I'm gonna go with black mirrors, grill and trim though. But the cut out center really flows with the cut out in the bumper. With an all black grill though it shouldn't make much difference
Build Thread : HERE
CAV3MAN227
-I like how its front mount and was able to keep all the front bumper grill stuff and fog lights for that matter. I lost all that. Great looking car.
-Joe
Yeah, I wish I could have kept the front bumper cross & vertical slat pieces. I think it would have looked better, but they wouldn't work with the intercooler. I with the end tanks were a little more rounded. It would go with the styling of the car better.
xise
Post by xise »
Did you fit any of those wheels yet? I would love to see how it looks with hmmm....all of them lol :D Seems like you are the type to try them all out for looks no?
CFK
Post by CFK »
Not yet , the exterior of the car is fully re-assembled. Just getting the interior back together, sway bars and the shifter assembly. Kicking it out of the garage and powdercoating the Speedlines. Then I'm all done !!!........... Hopefully :roll:
I'm hoping 2 weeks max, get it on the road . First thing is a photoshoot !!!
Build Thread : HERE
CFK
Post by CFK »
Some Progress :
- All Trim Painted, Bumpers On
Some Bars
WRX / TWM Short Shifter & Kartboy Bushings, STI Titanium Knob.
Gross
Rebuilt the Rack, Pinion seal still leaked :smt022
Upper Pinion seal leaked after re-installing :smt013
Serious Quality Control Issues at Beck Arnley. ( Both Brand new ) Can you tell which ones Made in Japan :?:
Keeping Busy until Gear Box Seal Kit "A" Arrives, Hand Polished 330mm Momo from my Jetta.
Also got a JDM Nardi Wheel, but its almost stock size, i'll have to try both :
Stock Oblong Control Arm bushings Compared to Forester Units
Craigslist find Group A Mounts, Awaiting the Motor mounts from Subarugenuineparts.com
Mounted me Racks while waiting for the Pinion Seal Kit
Thanks to Mike Tracy for Grabbing stuffs from the Wrecker for me :!:
Build Thread : HERE
Re: CFK's 92 SS Daily/Project (Updated Mar/11/2013)
So is that trim guard you used black instead of the factory chrome? Did you just paint the door trim pieces since the chrome strip is integrated into the trim piece?
On the shifter setup, are you using the factory Subaru u-joint?
