Re: Lets talk Suspension upgrades for a 1990 BC Leggy
Posted: Thu Jan 16, 2014 7:09 pm
I like the list above.
I however felt more of a difference with the steering rack bushings. Depending on the condition of your existing engine, trans, & trans crossmember bushings will determine how much of a benefit you see. Honestly, I'd start with the shifter linkage bushings. Do the front & rear shifter stay bushings from kartboy, and replace the old shifter joint bushings or get a newer shifter assembly and the new shifter joint. I don't personally care for the short shifters with these transmissions. The shifting effort increases quite a bit (at least in my old 5spd) and actually made driving less enjoyable.
I didn't really notice much difference with the crossmember bushings when I was running the STi engine & trans mounts, but again it depends on the condition of your old ones.
I can tell you the rear diff bushings in the unabomber's rear end kit probably won't work. I do think the lock bolts and front outrigger bushings are definitely worthwhile doing. If you want to do the rear lateral link bushings too, you can, but I don't know if they'd be the first thing on my list.
These are really the only rear diff carrier bushings I've found to work with our cars.
http://www.main.experiencetherave.com/s ... fbushings/
