robertpaige
Post by robertpaige »
@just-rust,
It's going in today. I'm stokeddddd. My clutch is bad though so I won't be able to feel the power in full effect.
dankberries
Post by dankberries »
My buddy accidentally knocked a beer glass off my 2nd floor balcony and it landed on my legacy :-(
Surprisingly the beer glass didn't break lol.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Wow, that sucks big time...
CAV3MAN227
Post by CAV3MAN227 »
-Coolant temp sensor, fuel filter and seafoam.
-Joe
rallyak
Post by rallyak »
I been needing to get rid of my parts car so I striped a few parts of the front all the relays.
Charles
robertpaige
I am trimming my bumper to fit
my MASSIVE front mount.. Lol
I've been there a couple times robert, lol.
10wrxing
Post by 10wrxing »
Installed my keyless entry today.
http://youtu.be/PMGqohQCMv0
Still have some cleaning up to do, but had to stop since it started raining, and I gave up my double car garage to store 2 of my cars for the winter.
I saw your pics on facebook. Have you tried it with the door panel on? I remember having issues on my car with the actuator outside the door like that.
10wrxing
Post by 10wrxing »
cj91legss wrote:I saw your pics on facebook. Have you tried it with the door panel on? I remember having issues on my car with the actuator outside the door like that.
Hey,
I followed the directions from this thread here:
http://bbs.legacycentral.org/viewtopic.php?f=19&t=42955
I measured and used those pictures to gauge where to put the actuator.
Afterwards I tried the door panel on and it fit perfectly.
just-rust
Post by just-rust »
The old VF11 decided to take a permanent vacation after 236,000 miles. Been putting in the td04 I had lying around. Fully welded exhaust system is not making the DP go on nicely. Tomorrow, hopefully I win.
Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
just-rust wrote:The old VF11 decided to take a permanent vacation after 236,000 miles. Been putting in the td04 I had lying around. Fully welded exhaust system is not making the DP go on nicely. Tomorrow, hopefully I win.
3" V-band flanges are amazing, I think I paid 20 bucks for a pair with clamp on ebay. Worked out pretty well for me.
just-rust
Post by just-rust »
Today I won! td04 success and the V-band flange is an excellent idea cj. Didn't take to long to wrestle everything out of the hangers but I would much rather just undo a clamp!
I installed a new shift knob today and the big difference between the old 2004 & 2015 shift knob is the weight. The 2015 shift knob is almost 3 times as heavy as the 2004 shift knob.
Here are pics.
http://main.experiencetherave.com/subar ... ishiftknob
CAV3MAN227
-Put an Optima battery in.
-Joe
robertpaige
New clutch is in, the master cylinder decided to take a crap so I can barely get the car in gear... the little things man. ugh
Need a good used one?
James614
Post by James614 »
Legacy777 wrote:I installed a new shift knob today and the big difference between the old 2004 & 2015 shift knob is the weight. The 2015 shift knob is almost 3 times as heavy as the 2004 shift knob.
Here are pics.
Does the heavier knob make it shift much better?
GTEASER
Post by GTEASER »
Over the weekend I replaced the old dead factory JECS fuel pump with a plug and play DeatschWerks DW200 and she's running again.
James614 wrote:Does the heavier knob make it shift much better?
I drove the Legacy to the airport this morning and while it's probably anecdotal, it seemed to shift smoothly. I honestly couldn't tell you at this point whether it was "better" or not. My main complaint with the old shift knob was the stitching at the 6 o'clock position. It would rub against the palm of my hand.
I'll try and remember to provide an update after I've driven it some more.
GTEASER
Post by GTEASER »
Finished the Sparco steering wheel install yesterday.
Finished the '04 WRX hood scoop today....no cutting, only 2 small holes drilled in the hood and the factory under hood deflector is retained.
And installed rear Rally Armors.
CAV3MAN227
-That wheel looks really good!
-Joe
GTEASER
Post by GTEASER »
Thanks! I am thoroughly enjoying it. Great driver interface mod.
I finally added notes and uploaded my dyno plots. It took a lot of time editing and adding the notes to the plots!
Here's a link to the post in my build thread.
http://bbs.legacycentral.org/viewtopic. ... 79#p431279
thewaterboy
Post by thewaterboy »
Got everything together, and it sounds great! I also fixed my coilover situation, and lifted the rears ½".
