Hey guys,
I've recently changed my front rotors and pads on my '91 Legacy
U.S. spec, turbo with 15" wheels with stock size rotors. The pads
are from Metal Masters. My problem is multi-faceted. First, the
pads weren't the same size as the O.E. pads, so I couldn't fit the
shims and the only one of the two anti-rattle clips would go on each
rotor. Secondly, I took it for a test drive to bed the pads and I'm
getting a metallic noise from the right (passenger side) rotor.
Could it be a rattle clip in the way. Do I need to find a proper
sized shim? All advice is greatly appreciated. Also I tried another
source of pads and they were identical to the Metal Masters.
Thanks,
Andrew Mouser
Take the Yahoo! Groups survey for a chance to win $1,000.
Your opinion is very important to us!
http://us.click.yahoo.com/NOFBfD/uAJEAA ... /XoTolB/TM
Front Brake Work Problem
is the noise there constantly or just when applying the brakes? If constant something is scraping, jack up the car remove the wheel turn the disc to see where.
If the pads were the wrong size I would not have fitted them and perhaps looked at a different brand..
cheers, Rod
----- Original Message -----
Sent: Sunday, May 19, 2002 76 AM
Subject: [BC-BFLegacyWorks] Front Brake Work Problem
Hey guys,
Thanks,
Andrew Mouser
ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.35 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014 ... =570504438>
cheers, Rod
Hey guys,
Thanks,
Andrew Mouser
ADVERTISEMENT
I'd say it's pretty constant scraping with increase
when the brakes are applied. I'm going to see if I
can match up the old pads at the parts store. Thanks
for your help.
Andrew
> where.
> brand..
> cheers, Rod
> From: furtherrad
> Problem
> Hey guys,
> on my '91 Legacy
> rotors. The pads
> couldn't fit the
> side) rotor.
> to find a proper
> Metal Masters.
> Thanks,
> Andrew Mouser
> ADVERTISEMENT
> email to:
> Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of Service.
__________________________________________________
Do You Yahoo!?
LAUNCH - Your Yahoo! Music Experience
http://launch.yahoo.com
for your help.
Andrew
> where.
> brand..
> cheers, Rod
> From: furtherrad
> Problem
> Hey guys,
> on my '91 Legacy
> rotors. The pads
> couldn't fit the
> side) rotor.
> to find a proper
> Metal Masters.
> Thanks,
> Andrew Mouser
> ADVERTISEMENT
> email to:
> Terms of Service.
Do You Yahoo!?
Those damn anti-rattle pads make more noise then they're supposed to
fix. Keep the little clips that go on the caliper there. But the ones
that go on the back of the pad....get rid of them. Buy some of the disc
brake quieter stuff.....get the red paste stuff from crc. it works the
best....smear it all over the back of the pad.....and you should be
golden.
That's the only stuff I've found that works very good.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
Sent: Saturday, May 18, 2002 46 PM
Hey guys,
Thanks,
Andrew Mouser
golden.
Josh Colombo
Hey guys,
Thanks,
Andrew Mouser
