clogged o2 sensor
Locked
limonoah
clogged o2 sensor
Post by limonoah »
If my o2 sensor is clogged or almost clogged, would it give a lean
reading or rich reading?
-NOah
axfinn_20902
clogged o2 sensor
Post by axfinn_20902 »
Noah: Bad O2 sensor produces a Lean condition.
axfinn_20902
clogged o2 sensor
aldad138
clogged o2 sensor
Post by aldad138 »
About how much for a new O2 sensor? Mine has 293,000 miles on it,
and after checking all the gaskets and vacuum connections, I still
have a rough idle intermittantly and thought maybe this O2 sensor
could be the cause. Anyone familiar with rough idle= bad O2 sensor?
A
limonoah
clogged o2 sensor
Post by limonoah »
A new O2 sensor is about $120 :(, or you could get a universal type
for less, but you would have to hard wire it in. Most likely if you
O2 sensor is bad, it will give you a CE light error code. Check the
codes before you pay $100+.
-Noah
Locked
