When did the change take place for the attachment of the rear sway bar links
from the Pin in a box droplink to the U shaped link? I was under the
impression that it was in 1992 however someone told me it was in 1995.
I converted my 90 legacy over in order to use the Whiteline HD links in the
rear. It was suggested that I use the lateral links from a newer Subaru but
instead I used the MRT adjustable in order to get more camber and toe
control plus new bushings.
Rear suspension, sway bar attachment to lateral link
Rod_
In Australia, the rear link that had the steel rod, was up to and inc 9 /1992. From 10/1992 it changed to the plastic U links ( same as the front links)
cheers, Rod in Oz
cheers, Rod in Oz
