quickshift?
206er
quickshift?
Post by 206er »
has anyone on here put quickshift shift improver in their tranny? I'm considering this, but have also heard that it wears out the clutshes prematurely... any thoughts?
jeremy
JasonGrahn
Post by JasonGrahn »
-Jason Grahn
paf
Post by paf »
haha
the search nazi has failed!!!
LOL JUST JOKING...
but the link you gave is invalid
and the post doesnt answer any questions....
1990 FWD Legacy Wagon Base
paf
Post by paf »
well that was a lame post (mine)
JasonGrahn
-Jason Grahn
206er
no...
Post by 206er »
I guess I should have been more clear. :oops: I have an automatic :cry: and am inquiring about a tranny fluid made by B&M. I know short shifters are great in a manual trans.
jeremy
fluid will not change the speed in which a tranny shifts.
Shift kit will help slightly,
http://www.txchange.com/sk.htm#Import
I've got one in mine. It helped the 1-2 shift
SK® RE4R01A
Nissan RE4R01A, RL4R01A Mazda R4AX-EL, Subaru 4 speed ECAT, Nissan – Infinity – Truck - SUV V8 RE4R03A, Isuzu Diesel JR403
1988up 4 speed with or without lockup
Corrects/Prevents/Reduces:
Planetary burnup; 3rd clutch failure; forward clutch burnup Soft 1-2 shift; 2-3 cutloose; Band burnout and low lube flow causing overheating and total burnup
paf
Post by paf »
now im interested...
how do those work???
like I said, the biggest improvement I noticed was the 1-2 shift. It also helps inherant issues with the auto tranny. My tranny was pretty tired when I had it in, so it didn't fix all the issues I have.
paf
Post by paf »
how much am i looking at ($$$) if i want one of those... easy to install???
206er
Post by 206er »
wow those sound pretty beneficial. waht is the kit made up of?how much? do you have to drop the tranny or just the pan?
regards,
jeremy
kit was like 60 bucks I think....or possibly less....don't remember.
The kit is meant to be put in when rebuilding the tranny, however you can just use the parts meant for the valve body and be ok.
If you do what we did to my tranny, you'll need to drop the valve body and basically take it completely apart, and add the appropriate parts to the correct spots.
This is not a job for a do-it-yourselfer unless you have a very good background with internals of an auto tranny.
