quickshift?
Posted: Tue Jun 10, 2003 6:29 pm
by 206er
has anyone on here put quickshift shift improver in their tranny? I'm considering this, but have also heard that it wears out the clutshes prematurely... any thoughts?
jeremy
Posted: Tue Jun 10, 2003 8:32 pm
by JasonGrahn
Posted: Tue Jun 10, 2003 10:01 pm
by paf
haha
the search nazi has failed!!!
LOL JUST JOKING...
but the link you gave is invalid
and the post doesnt answer any questions....
Posted: Tue Jun 10, 2003 10:04 pm
by paf
well that was a lame post (mine)
Posted: Tue Jun 10, 2003 10:20 pm
by JasonGrahn
no...
Posted: Tue Jun 10, 2003 11:35 pm
by 206er
I guess I should have been more clear.
I have an automatic
and am inquiring about a tranny fluid made by B&M. I know short shifters are great in a manual trans.
jeremy
Posted: Wed Jun 11, 2003 1:05 am
fluid will not change the speed in which a tranny shifts.
Shift kit will help slightly,
http://www.txchange.com/sk.htm#Import
I've got one in mine. It helped the 1-2 shift
SK® RE4R01A
Nissan RE4R01A, RL4R01A Mazda R4AX-EL, Subaru 4 speed ECAT, Nissan – Infinity – Truck - SUV V8 RE4R03A, Isuzu Diesel JR403
1988up 4 speed with or without lockup
Corrects/Prevents/Reduces:
Planetary burnup; 3rd clutch failure; forward clutch burnup Soft 1-2 shift; 2-3 cutloose; Band burnout and low lube flow causing overheating and total burnup
Posted: Wed Jun 11, 2003 1:22 am
by paf
now im interested...
how do those work???
Posted: Wed Jun 11, 2003 1:30 am
like I said, the biggest improvement I noticed was the 1-2 shift. It also helps inherant issues with the auto tranny. My tranny was pretty tired when I had it in, so it didn't fix all the issues I have.
Posted: Wed Jun 11, 2003 1:44 am
by paf
how much am i looking at ($$$) if i want one of those... easy to install???
Posted: Wed Jun 11, 2003 2:52 am
by 206er
wow those sound pretty beneficial. waht is the kit made up of?how much? do you have to drop the tranny or just the pan?
regards,
jeremy
Posted: Wed Jun 11, 2003 2:00 pm
kit was like 60 bucks I think....or possibly less....don't remember.
The kit is meant to be put in when rebuilding the tranny, however you can just use the parts meant for the valve body and be ok.
If you do what we did to my tranny, you'll need to drop the valve body and basically take it completely apart, and add the appropriate parts to the correct spots.
This is not a job for a do-it-yourselfer unless you have a very good background with internals of an auto tranny.
