Heater
Heater
Well I had mentioned that the vents didn't blow a few days ago. Well now the car, when the heat button is pushed only blows out hot air 50% of the time. The Temp gauge is in the middle where it should be, but no hot air. Then all of a sudden my feet get warm and it is blowing hot, then it will turn cold again. Since it is getting close to cold weather I really need to get this one fixed. I thought I would come here first and ask for suggestions.
JasonGrahn
definitly sounds like a pocket of sorts is in your coolant system. I've used this before to make sure no pockets are left. a very GOOD tool to have.
see this tool: http://toolcraze.com/Merchant2/merchant ... gory_Code=
http://www.all-tool.com/BY_MASTER_CATAG ... vice_3.htm
http://www.costplustools.com/store/show ... t_id=39198
as you can see, prices vary. but they stay around 20 bucks.
-Jason Grahn
