JDM water-air ???
JDM water-air ???
Is this unit will work as "bolt on" on our cars??? or need some aditional parts?
2000 Impreza WRC:) (Daily)
1991 Legacy Turbo (RallyX)
1994 Legacy Turbo (spare for RallyX)
2000 Legacy Outback (daily wife)
2002 WRX sedan 350-400 hp - Tom
2002 WRX sedan (parts store)
What pump I‘ll need for this? The car have water pump, do I need extra one??
Dos any one did this conversion before?
Any info will be appreciated.
Jack
Jack
get a pump that flows about 15-20litres/minute, try to get a custom front heat exchanger that is almost as big as your radiator, I have heaps of pics of it installed, PM me and I'll email them to you.
Do a search for it. It takes a little more than just putting it in, the hard parts are clearing the coolant tank, and the turbo to IC pipe. I took out the AC (didn't work anyway) but I think it could be made to fit around the AC pipes. It is a lot of work to get it installed but I think it was worth it.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
93 Sport Sedan, 5mt
After search:
http://autospeed.com/cms/A_0090/printArticle.html
