garrett T-series
legacy92ej22t
garrett T-series
is anyone using a T3,T4,T25 ect...does anyone know how well they go into the legacy turbo?is one better then another for the ej22t?i've been searching for a good upgrade at a good price on ebay and a lot of garrett's are on there.also looking into the mistu.tdo5 and tdo4,and the ihi v-series turbo's.what are those of you that have upgraded running and how was the experience?thanks
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Garrett turbos...
Age and treachery will overcome youth and skill!
Redline Dreamz
yor waisting your time with that T28. The T28/GT28 series turbos were designed for quick spool and outragous rpm levels of the Honda 1.6L and 1.8L engines. Using such a whimpy turbo on a 2.2L is just not the right idea. The TD05 doesnt spool near as quickly as stock but it does pull very hard on top... i know becuz i swapped one into "Frmrgs2rchs" car. If you wanted to stay Garret then the better choice would be the GT30/T32. These are made for engines between 2.0-2.5L and will allow a 7500rpm redline to stay on the compressor map. Theywill not spool quite as fast but are good for much more horsepower on the top of your power band.
All kinds of cars but none of them run.
GT28 turbo series...
Redline Dreamz
hold up now i never said they wouldnt work, i just said that they werent really designed for a larger displacement engine. You can swap out comperssor wheels to fit it to your engine but its costly, timely, and takes some skill and i never automaticaly assume that people know how to rebuild turbos.
Theyll make the horsepower, but for anything above a 2.0L i would expect nothing less than the potentail for 450hp from a turbo. I have a 2.4 DOHC in my Z24 and a T28 is just too small, it would spool too quickly. A more proper fit would be a T3/T04S... spools at 3000revs and still has the potential for more than 500hp. Its not BAD to use a small turbo however youll have a lot more trouble breaking 300bhp barrier. IF your not interested in doing so then i suppose a T28 would fit your taste. Though i still recommend the TD05 (small 16G)The T28/GT28 series turbos were designed for quick spool and outragous rpm levels of the Honda 1.6L and 1.8L engines. Using such a whimpy turbo on a 2.2L is just not the right idea.
