Getting trouble codes on 91 legacy
jlegge007
Post by jlegge007 »
My book says to disconnect the one wire plug harness under the lower dash panel. Turn on key and wait for trouble codes to flash. If the connector is not disconnected the CEL will flicker. Well I cant get any codes and if I connect the the one wire harness, I dont get a flickring CEL. Is there something else that I have to do to get the codes? Stumped in Pa.
Thanks,
Joe
check out my site for more info and pics on pulling codes. Info is in the notes & tips, engine related.
jlegge007
Awsome site!
Post by jlegge007 »
This is great, That you share your info! Thanks!! I will be referring to your site quite often.
Joe in Pa
welcome.
May also want to check out tech info on my site as well, owners manual, factory manual, parts manual.....
