pulling entire rear suspension
EJ22TGC8
Post by EJ22TGC8 »
I'm doing a full rear swap and I need to get everything off. I got the trailing arm and the rear conrtol arm and sway bar off but I can't for the life of me figure out how to get the forward control arm off. On one side is a bolt and on the side where a nut should be there is some huge adjuster thing with teeth on it. Anyway how do I take that arm off?
Opie
Post by Opie »
Thats just a rubber cover to keep the nut that is under it from puncturing the gas tank in an accident, it rotates (counter-clockwise I think) and pops off, or you can pop it off with a flathead screwdriver.
2000 Legacy B4 RSK, 2013 BRZ-Track car, 2021 Forester Sport
