An AWIC and A/A IC idea, although probably not a good one.
How benificial would it be to ad a small air to air intercooler to the piping system of an AWIC? For instance, what if you used a small heater core from a truck or something and stuck it up next to the heat exhanger for the AWIC, but used it to throw air through instead? You could run the pipe through that then run it back to the AWIC.
hehe, I know it probably sounds abserd, it probably would have a lot more lag, and the drawbacks of using it may not outway the benefits, but for some reason I was thinking of this the other night. Has anyone ever heard of something like this being done?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
You mean to essentially put an air/air intercooler in parallel with the air/water intercooler?
I don't see what the benefits would be... The only disadvantages (that I can think of) of a proper air/water intercooler setup would be weight and complexity, and this setup would hurt both, no? Or am I missing something?
rsstiboy
you mean put a air/air cooler instead of the front water heat exchanger? why not just get a bigger heat exchanger and water pump? if you were going to convert your water/air to air/air it wouldnt work, have you seen the size of the hoses that carry the water to the intercooler? it would defeat the purpose of putting a front heat exchanger on there.
JUST GO FMIC
JUST GO FMIC
Well basically it would run the full on AWIC setup, and then you'd have a small front mount sitting there too. Like Ciper said though, it probably wouldn't have any benefits.
2014 Volvo S60 T5
2014 Volvo S60 T5
rsstiboy
I don't understand what you guys are trying to do. the AWIC is full of water. the air/air is full of
air
to put a fmic you would have to extend piping all the way down the front of the car and back to the inlet manifold, hence defeating the purpose of having a short air path in the water/air setup.
Well I wasn't "trying" to do anything really. I was just throwing an idea out there which I thought was probably a bad one, and I wanted to see what other people had to say about it.
2014 Volvo S60 T5
2014 Volvo S60 T5
scottzg
usually, if i use my turbo for any length of time, im goin pretty fast.ciper wrote: Yes but not defeating the fact that a water intercooler has a huge buffer. A water intercooler can function just fine standing still, an air/air unit needs air flow constantly to work.
I think ciper said it best about running a duct to the air/water heat exchanger. That way you aren't really adding any complexity to the system or lengthing the intake tract as with front mounts...And you will probably get some cooling effect on both the intake air and the water in the exchanger. Probably not really very much...but maybe if you designed a water/air exchanger from the start with this in mind, and set up a nice splitter or whatever to direct air over it. Of course you wouldn't want to lose any efficiency at air/water heat exchange in the process...
Thats what I get out of kicking that idea around.
Micum
Micum
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
"usually, if i use my turbo for any length of time, im goin pretty fast."
Yeah once you are DONE using the turbo. While getting up to that speed the amount of air isnt as great. With the water system it acts like a buffer until enough air is passing. You are able to run HIGHER than normal boost possible with a water system because of this, but only for the amount of time you have water capacity for.
"running a duct to the air/water heat exchanger."
Not the radiator, he is speaking of cooling the intake air to water heat exhcanger.
rsstiboy
you mean the intercooler, the heat exchanger is at the front of the car.
just remove the bonnet vent cover on the underside of the hood that will direct air over the intercooler, it does jack shit I can vouch for that.
They are both heat exchangers.
The original post about running a duct was about an AIR to AIR setup which only has one heat exchanger.
If you want to get technical about it then what you call an intercooler isnt even that. Intercooler means a cooler in between two units (turbos for example). Its an aftercooler
The front is referred to as a radiator, just like the one used for engine coolant.
I dont agree with removing the vent cover. Underhood temperatures feel higher when its not installed.
So your saying that by removing the vent cover it makes things worse ciper? The underhood temperatures go up?
2014 Volvo S60 T5
2014 Volvo S60 T5
Yeah, the cover pushes air over the turbo and under the vehicle. If the scoop is removed alot of the air exits on the left side of the vehicle letting more heat from the turbo.
I didnt measure the temperature, it was just through feeling. I guess I could be wrong but think of it this way, why did subaru put a vent with cover and chimney if it served no purpose? I see no reason to cool the transmission, remember the back of the engine is in front of the scoop.
Yeah I realized what the scoop did, but I didn't realize that it was THAT affective with cooling off the turbo, but it does make sense.
2014 Volvo S60 T5
2014 Volvo S60 T5
rsstiboy
the scoop doesn't get much airflow at all, its designed to vent the hot air off the turbo keeping engine bay temps down, air flowing over the turbo doesn't cool it much at all, and the air still vents off the turbo without the cover, i had mine removed but only to fit the FMIC piping
oh, and ciper, it is a intercooler as it is between two units, 1 turbo and 1 engine.[/code]
rsstiboy
don't you guys have a turbo 'shroud' to help direct the air up and out the bonnet vent? it works just fine without the vent cover. the amount of air that the scoop collects is negligible, thats why I called it a vent, because it does stuff all other than that.
The hood scoop and shrouding on the US turbo legacy does two things.
It does direct air over the turbo through the backing collector on the scoop and down the "chimney" thing over the turbo. I think that setup does do what ciper said, but I couldn't tell you how much air the scoop brings in or how effective the setup is.
Secondly, when the car is off, the heat from the turbo goes up the chimney and out the scoop....With the location of the turbo and duct work it makes a convection current of air to draw air from underneath the car up over the turbo and out the scoop to help cool things down.
rsstiboy
ok, yours has the chimney too, you'll notice the insect screen at the top - very bad for airflow unless its rising off the turbo, if the scoop was bigger it might be able to cool both ways but its not big enough to do that.
