disable ABS?
disable ABS?
ok so when somone replaced a stud on one of my hubs they totally messed the tone ring, right now i dont have the time or money to replace it and i was wondering how to fully disable the abs so i have normal brakes (and actually after driving cars without abs for years i like it better not having it...).
92 legacy turbo auto awd, no mods yet
96 svx, still a baby
ej22t
The ABS fuse should be at the fuse box inside the engine bay, when you open the box and you will see ABS on the sticker underside on the cover, it should be a big red with 40A on it, take it out and your dash will turn on the ABS light but it will be fine. When you put the fuse back then the light will go off.!
Ben
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
From a look at the diagrams, I'd say disconnecting the 12-pin round connector from the hydraulic unit underhood should make the light go away. You might want to cover the exposed connectors up with tape or something just to keep the terminals from corroding just in case.
rallysam
If I drive around with the ABS fuse pulled, does that cause any problems? Are there any safety issues? Does it do anything funky? Or does it really behave just like a normal car without ABS?
'00 Impr RS - sold
It will behave like a conventional car without ABS. That was a huge engineering problem when ABS was first designed: how to make sure you wouldn't lose braking functionality when the ABS system failed. If you disable the ABS computer the hydraulic unit is completely inert in the braking circuits.
That's good to know. It might be benefitial to turn off the abs if I ever autox the car. Has anyone found that they like ABS during auto-xing?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
rallysam
In RallyX, I find the ABS maddening. I haven't autoX'd enough to make an informed opinion.
'00 Impr RS - sold
