Moderators: Helpinators , Moderators
dagsy
Posts: 55 Joined: Tue May 20, 2003 11:04 pm
Post
by dagsy » Mon Apr 05, 2004 5:27 am
would there be much drama in attempting to do this. auto is on the way out, but all the manual boxes around are fwd. or just get the auto fixed?
cheers all
Posts: 27936 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Mon Apr 05, 2004 2:43 pm
Not sure what you would do with all rear drivetrain stuff, hubs, axles, rear subframe, etc. They're different on the FWD's & AWD's.
I'd try and find an AWD MT, or just repair the auto.
dagsy
Post
by dagsy » Mon Apr 05, 2004 11:18 pm
would have to agree totaly with that josh, especially after having had a look at under the rear of the car last night. just to hard.
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Mon Apr 05, 2004 11:29 pm
Couldn't you just hacksaw the rear axles off near the hubs, and then remove the diff, driveshaft, and the rest of the axles? Or would they flop around too much and destroy the wheel bearings?
mTk
no title
Posts: 1316 Joined: Sat May 03, 2003 6:29 pm
Post
by mTk » Tue Apr 06, 2004 12:10 am
You could just leave the rear diff and axles installed. Detach the axle from the diff, everything is held up there pretty good.
MK
1992 BC672 AWD 5MT
Post
by vrg3 » Tue Apr 06, 2004 12:17 am
The differential's input doesn't need to be protected from the elements?
Posts: 9809 Joined: Mon Jun 16, 2003 11:20 pm
Post
by evolutionmovement » Tue Apr 06, 2004 12:19 am
Switch with fwd rear hubs and struts and sell the AWD parts.
ciper
Posts: 4388 Joined: Tue Oct 15, 2002 8:16 pm
Post
by ciper » Tue Apr 06, 2004 4:13 am
The transmission will leak fluid if the driveshaft is removed, unless you plug it up with something.
Whats the point anyways, maybe we can find an alternate solution to your problem.
Post
by vrg3 » Tue Apr 06, 2004 4:18 am
The transmission fluid? He'd be putting in an FWD transmission.
mTk
no title
Post
by mTk » Tue Apr 06, 2004 4:25 am
the input on the rear diff has a nut int it that is normally covered.. he could bolt a small plate to it w/ the stock bolts, or duct tape even
MK
1992 BC672 AWD 5MT
ciper
Post
by ciper » Tue Apr 06, 2004 4:29 am
Missed that part. I thought he was wanting to use an AWD transmission as a FWD like the sand rail guys do.
