I have the jump on some 2.5 sti heads with manifold.
subiekid
Are you guys sure they will bolt right up to my ej22T? I have searched and not found to much on the sti heads/ej22T block.
Dustin
Dustin
1995 Subaru Legacy Sedan - Ruby Mica - Turbo - EJ22T transplant
legacy92ej22t
I had heard something about using the EJ257 heads on the EJ22T block on NASIOC IIRC and the head bolts need lengthened or something but besides that they worked. I don't actually know personally though so....
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Have you tried this Kelley? Is there any problems with the coolant passeges lining up with our blocks, like the 2.5 n/a heads have?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
subiekid
Kelly, what is your ecu? the vvt for the sti's work on their own at a certain rpm and dont require the ecu to turn them on. It will not be as much of a gain as if i would have the sti ecu, but it will still be better then nothing. I am running a TEC 3 stand alone ecu, so i am not sure how your ecu would work with it. As far as I know no aftermarket ecu will be able to controll vvt.
Thanks for the input
dustin
dustin
Some ECUs can control the VTEC switch, but I don't know about Subaru's system. How does it work - does an increase in oil pressure drive it and how variable is it? Is it a simple can lobe switch like Honda or a more variable system like some other manufacturers use?
is this for real sti heads will fit on a ej22t motor come on, does any one now for sure 150% what would i need intake manifold and heads.
