My First Trip to the Drag strip with the Legacy
NemesisEJ22t
Well, i ran my car at Pittsburgh Raceway Park last night for the first time, and i am fairly happy with my results. My best time was a 15.708 @ 86.08 MPH. My 60' time was a 2.226 which is pretty good for what i'm doing I think. I was surprised at how much you can feel the AWD hurting the performance of 3rd gear. The launches seemed to be really good, except for one where i bogged the engine and pulled a 2.5 60'. The car was running 14-15 psi with the Saab 900 IC, vrg3's FCD, and a MBC. Those are all the mods i have done so far. The clutch was slipping pretty badly on the way home so i am thinking that i might have better results when i replace that. All in all, considering the mods i've done, i think it was a pretty good showing. I'll try to scan the slips for you guys sometime soon and post them up.
Ben
91 Celica All-Trac @ 0 psi (turbo being installed)
92 Celica Turbo FWD (swap) @ 12 psi HOLY CRAP!!! I miss AWD
legacy92ej22t
Cool. Ya, you better get that fixed before the Legacy meet at Beaver Springs!
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
NemesisEJ22t
Don't worry, i'll have it working fine as soon as i get the Celica running again. I don't have the garage space with the Celica on jackstands in there and i'm sure my parents would love to have a second non working car occupying the garage. If i have the money i will also have a bigger turbo for it by beaver springs.
Ben
Back the boost down! On a stock exhaust, 14 - 15psi is COOKING everything. There is a TON of backpressure with that much boost and the stock exhaust can't handle it all.
Drop the boost and you'll see lower EGT's and lower cylinder temps. The car will run cooler, and you'll have less of a risk of detonation.
The WRX clutch and Flywheel is a great idea. I have an Exedy Stage 1 in my car, and it made the car feel COMPLETELY different.
Lol, that's not how backpressure works. Backpressure making torque is a myth. Backpressure is the enemy of an exhaust system.
dscoobydoo
I have to agree, you might back down the boost- until you get a better exhaust. I am holding mine at the 7-8 until I do the complete 3' system for intake and exhaust. While the Intercooler will help, and the mbc/fcd can get you to the 14-15, its not breathing better.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
People think backpressure makes low end torque because they don't understand pulse tuning and then these statements get passed around until it's accepted as fact without question. On a turbo engine I don't see how it could be of any help at all.
