I have a proposition... i hope it is not too far fetched...
If anyone has kept track of my stalling problem, its basically narrowed down to the IAC or TPS... both very expensive sensors to buy...
Is there anyone in the NYC area with a 90-94 NA legacy that wouldnt mind me borrowing their tps/IAC for a test run or a spare so i can determine which is the problem?
Konrad
Anyone in NY help me out.
You could test the tps yourself following these instructions:
http://www.main.experiencetherave.com:8 ... sting1.jpg
http://www.main.experiencetherave.com:8 ... sting2.jpg
http://www.main.experiencetherave.com:8 ... sting3.jpg
Is the ecu throwing both codes or something?
well if there's no codes being thrown it's probably not either of those. Did you go over all this info in a thread before? If so what's the link? I don't want to suggest you do things that you already did
yeah i went down that way... well if its not the sensors... ive changed the fuel pump/filter, fpr, full tuneup, vacuum tested... i am really at a loss here. If its mechanical something is sticking after a long drive.. but ive cleaned ou the IAC assembly, throttle valve and all that. Im about to drive the damn car off a cliff
http://bbs.legacycentral.org/viewtopic. ... highlight=
Those are all the threads i can recall that have any info on the problem.
