STI Exhaust
STI Exhaust
I have a line on a relatively new 04 STI turbo back exhaust. Has anyone done this? Any problems or fitment issues. What were the benifits?
Thanks for any info
Frazer
Thanks for any info
Frazer
04 modified XT
99 LGT Limited
99 LGT Limited
you're going to have to increase the overall length of it. I'm not sure where but the impreza has a shorter exhaust system since the wheelbas is shorter.
It's identical to the stock WRX system (minus a mounting point difference because of the wider tranny tunnel). The stock WRX system is almost identical to the stock Turbo Legacy system.
Not worth it unless it's free, IMO.
LegacyT
I agree, the only benefit from an STi exhaust is the muffler with STi stamped into it. The system may sound a little better, but who knows on a Legacy. I'd rather spend a bit more money and get a nice 3" turbo-back.
Mark,
Mark,
The STi muffler flows better than the WRX system. But if you look at it.... it's still gots plenty of backpressure. I could have got one for cheap until I saw the little piping do two 90 degree bends before entering the muffler. It just doesn't look right after staring at 3 inch exhaust going straight back all the way from the downpipe.
stillkckn
We've had the CES Racing (WRX) exhaust on our STI, and it went on just fine. There is an issue, but it is not with the fit. There are reports of boost creep with free-flowing 3" systems on the STI, and there is some evidence of boost spiking. We think we know how to fix the spike (simple "tweak"), but the creep (if it can be documented) may require a more serious mod (like porting the wastegate).
If you're interested (here), I'll post the results of what we find, though there is no telling how long it may be before I can do much with my STI (it is sitting, on it's rotors, having been dropped off by the insurance company, as a total rightoff)
Jeff
That Sucks
Sorry to hear about your sti, what will you do with it??part it out
Just kidding, Thanks for the info Guys, this has been very helpful, maybe i'll invest my money elsewhere...
Frazer
Frazer
04 modified XT
99 LGT Limited
99 LGT Limited
the mid pipe or the axle back ( your call ) needs to be extended 6 inches and one hanger on the muffler needs to be lenghtenes and the midpipe hanger needs to be moved if you want. i didnt move it on my tbe because the hangers for the dp and the axle back were suficcent in holding it up
-jason
legacy92ej22t
Are you trying to do it in SS? Call around to piping companies. Also try places that work on diesel trucks, or places that make Pharmacutical equipement. I got mine from the later.Mackenzie wrote: but where would i get a 3inch ss pipe that is six inches?
If you're in a larger city then there should be exhaust shops that work with SS.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
hey guy i just brough the hallman boost controller now i read that i should have " One is a free flow exhaust. Backpressure causes heat in the turbo and as small as the stock IHI turbo is already, you do not need anymore. At the least, you should have a 2.5" or 3" cat-back system with a very free-flow muffler. It would be ideal to have the downpipe since that is probably the biggest restriction in the system"
dunno which should a get my achivement would be around 200-300hp.
i try looking on internet about downpipe i dint find anything usefull
anyone have suggestion
homegrwn97
The WRX header is identical, except for the O2 sensor hole. AFAIK, the STi is also the same, diameter and all.
The WRX turbo-back exhaust diameter is 2.25", where the STi is 2.5" AFAIK.
My STi exhaust is extended at the midpipe, and the hanger points on the muffler are moved.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
homegrwn97
Good info! thank you!ScottyS wrote:The WRX header is identical, except for the O2 sensor hole. AFAIK, the STi is also the same, diameter and all.
05 LGT Wagon & 91 SS
SLODRIVE
I can say for sure that the STi header is identical to the Legacy unit besides the O2 hole (for which there's an undrilled boss on the Legacy one). I had both in my garage at the same time, and I only used the STi header because the other one was caked in old mud.
http://www.slodriveracing.com
-And more!
-And more!
