Fuel Gauge WTF?! OMGz!
JasonGrahn
so my fuel gauge started something new the other day: It only goes up to half tank.
I filled my tank w/ 11 gallons, drove down the road, found that it only showed half. "Well that can't be true" I thought to myself, "I just put in 11 gallons!"
Thoughts on a process to troubleshoot this or a method of solving?
Thanks.
Thanks.
-Jason Grahn
yeah....the senders get corroded. I think it's more common on the 95-99 legacies. You can take the senders out, and usually buff the piece of copper/brass or whatever so that the corrosion goes away and things are working again.
- quasi-mod-o
Exactly the same problem my 91 turbo friend is having. I'll let him know about that...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Another car, soon to be announced
tell that guy that if he needs more information to post. Also I heard that the driver side of the tank is for the top half of the gauge and the pass side is for the bottom half (the senders at least), but who knows how true that is.
I just replaced the sender on mine (only one) and it was a very easy job. I tried cleaning it off and reinstalling it before replacing, but that did no good. There were no apparent problems from the outside.
- quasi-mod-o
Again I say, he has no internet accessTHAWA wrote:tell that guy that if he needs more information to post.
tris91ricer
- Title Whore
Could bad senders also be the reason why my gauge moves around when i go downhill? If i take a steep downhill (road) at 1/4 tank, when i reach the bottom, or somewhere flat and level, the gauge will read E. however, with acceleration and movement, the gauge will go back to what it should be... this is annoying --would new fuel senders solve this as well?
Thanks,
Thanks,
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
tell him to stop makintg excusesubyluvr2212 wrote:Again I say, he has no internet accessTHAWA wrote:tell that guy that if he needs more information to post.
LaureltheQueen
- Spelling Nazi
the senders are located towards the rear of the tank. if you are very low on gas, and your light comes on, then you drive up a hill, the light will fade until you level out again. Spirited acceleration has the same affect on you gas gauge
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
tris91ricer
- Title Whore
Which models have a fuel light? Does my 91 L have it? Maybe i don't see it cause i still don't have illumination.. but there's a light?? that blows me away.. hmm. but yes, what laurel just described sounds about right..
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
JasonGrahn
LaureltheQueen
- Spelling Nazi
