Take a look at what has been rigged so far... coolant tank will be where the washer tank was, washer tank's getting moved to the trunk until I can find a smaller one or swap back with the battery.
Tomorrow it will be getting finished. Coffee mug mod and MBC also in today - when doing these at the same time you only need to put the two larger hose fittings on the mug, the small one is not needed with the aftermarket boost control.
Lower BOV vaccuum line is run over top of the intake manifold and just left there, it is an atmospheric reference and I just didn't want my new WRX hood scoop to fill it with water by leaving it unrouted. Photos of that to come tomorrow too, hopefully. Why yellow silicone hose? It was pretty much the only way that I had to get the line size I needed that wouldn't disintegrate with vapors (for the canister line from the mug) and it just so happened to come with sizes for the BOV as well. A bit more color than I like under the hood but hey...
With some careful placement, IC has good clearance from the firewall and throttle plate. That's a "2 inch coupler" from home depot that's somehow fitting over the TB and then tapering down to the IC. IC's resting on foam taped to the top of the clutch fluid reservoir. Hood will be spaced up slightly and all will be cleared.
