t3/t4 turbo
Jason Gunn
t3/t4 turbo
Post by Jason Gunn »
Hi..Im new...I was just wondering if I could put a t3/t4 turbo on my 1992 Legacy. If so...would it be easy to do? Also another question...i was talking to someone one day and they said that their is a fuse that you can pull to make your all wheel drive subaru into front wheel drive! is this true? If so, which fuse is it........Can anyone help?
THAWA
Post by THAWA »
robsgotit
Post by robsgotit »
there is a fuse you can "put in" not pull, its located under the hood, on the passenger side firewall, it says"fwd" on it, its there for mechanical reasons, not to insert a fuse and do smokey burnouts, if you do that youll probly experince some tranny trouble down the line, and as for the t3/t4 its not plug and play, you should be ready to do some fabricating,
rob
"granny butterin, not double slicin like you should, your lucky that 100 shot of rye didnt blow the welds on the bread lifters, now me and the mad scientist got to rip apart the crumb tray, and replace the lifter springs you fried"
dzx
Post by dzx »
The fwd is only on automatic transmissions and the T3/T4 turbo is massive, you'd be looking at upgrading a lot more than just the turbo.
///M
'93 Legacy SS - part out
Jason Gunn
Cool.....Thanks for your help guys!
