I have access to an svx that is being parted out. I really really doubt the wheels would fit without any modification, but how far off would it be? While im at it, could i use the SVX brakes too? That combination stops the 3600 lb svx pretty good, imagine on my 2800lb legacy...
oh, and does anyone know the dimensions on those boogers?
Brat4by4 wrote:Can't you swap over the calipers and brackets and rotors? I thought all EJ cars had the same bracket attachment point.
The SVX is not a EJ car. It is a EG car. And Ciper is correct about the bolt pattern, although the are a lot more wheels that SVX owners have found that fit correctly.
Learn something new everyday. Brats are 4x140, try finding a wheel for that! Peugots used that size on some cars... but where are you gonna find those?
